When compiling an example program, I get this warning message:
marklagatuz$ make -f Makefile1
/usr/local/cuda/bin/nvcc -I /usr/local/cuda/include -o defIntegral_D.o -c defIntegral_D.cu
ptxas /tmp/tmpxft_00000949_00000000-2_defIntegral_D.ptx, line 65; warning : Double is not supported. Demoting to float
/usr/local/cuda/bin/nvcc -I /usr/local/cuda/include -o defIntegral_H.o -c defIntegral_H.cu
/usr/local/cuda/bin/nvcc -o defIntegral defIntegral_D.o defIntegral_H.o
marklagatuz$
Here is my makefile:
CUDA Installation Path
CUDA_INSTALL_PATH = /usr/local/cuda
Compiler
NVCC = $(CUDA_INSTALL_PATH)/bin/nvcc
Includes
INCLUDE = $(CUDA_INSTALL_PATH)/include
Program or Executable
PROGRAM = defIntegral
Device Code
DEVICE = _D
Host Code
HOST = _H
Create Executable by linking *.o (host and device object’s)
$(PROGRAM) : $(PROGRAM)$(DEVICE).o $(PROGRAM)$(HOST).o
$(NVCC) -o $(PROGRAM) $^
Compile device code to an object
$(PROGRAM)$(DEVICE).o : $(PROGRAM)$(DEVICE).cu
$(NVCC) -I $(INCLUDE) -o $@ -c $<
Compile host code to an object
$(PROGRAM)$(HOST).o : $(PROGRAM)$(HOST).cu
Remove *.o files and executables
clean :
rm *.o $(PROGRAM)
I don’t have any double variables declared within the example program. I’m confused on why this warning is popping up. I’m running on OS X 10.6.3 on an Intel Core 2 Duo with 9400 + 9600GT installed. The driver, toolkit, and SDK were successfully installed in their default locations. My example program works, but the warning message is an annoyance. haha!
If anybody can shed some light on this message, I would appreciate it! Thanks!
