Hello all
I need “isfinite(x)” as macro or define for a c++ programs. PGI obviously does not have that. Can I simply include the gcc math.h? I think this gives a mess?
Any ideas?
Thank you
Hello all
Any ideas?
Thank you
We have filed a TPR# 14280 for isfinite support in C++. Unfortunately, there is not easy way to fix a problem for now. We do include /usr/include/math.h but we leave out the C99 part.
If you can workaround in C, we support in C.
Thank you for reporting.
Hongyon
Dear Hongyon
Thank you for the answer.
The program is part of a library. So I would be grateful for the workaround in C. A macro would possibly be even better
Best
a_bra
You can just call isfinite in C. It should just work.
Here is example:
#include <math.h>
int checkme(float x) {
return isfinite(x);
Hongyon
For pgcpp, you can use:
% pgcpp -D_ISOC99_SOURCE
Hongyon
