When I try to compile the following code with pgc++:
#include <cmath>
int main()
double val = 0.0;
std::isnan(val);
return 0;
I get
pgc++ -o pgi_test pgi_test.cpp
“/usr/include/c++/4.3/cmath”, line 540: error: identifier “__builtin_isnan” is
undefined
return __builtin_isnan(__type(__f));
detected during instantiation of
“__gnu_cxx::__enable_if<std::__is_arithmetic<_Tp>::__value,
int>::__type std::isnan(_Tp) [with _Tp=double]” at line 6
of “pgi_test.cpp”
1 error detected in the compilation of “pgi_test.cpp”.
Is this an issue with my installation or an issue with pgc++? Is there a possible workaround?
pgc++ is pgc++ 13.6-0 64-bit target on x86-64 Linux -tp nehalem
g++ is g++ (SUSE Linux) 4.3.4 [gcc-4_3-branch revision 152973][/code]
