Hi, I’m using pgi compiler for a code with openACC derivative. I encounter the following compiler errors and I have no idea what is the issue. Before I use pgi compiler, I was use g++ and compiles with no problem. Could anyone help me on this?
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/usr/include/c++/7/new: 169)
PGCC-S-0039-Use of undeclared variable (/usr/include/c++/7/new: 169)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/usr/include/c++/7/bits/stl_vector.h: 116)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/usr/include/c++/7/bits/stl_vector.h: 671)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/usr/include/c++/7/bits/stl_uninitialized.h: 206)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/usr/include/c++/7/bits/stl_uninitialized.h: 210)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/usr/include/c++/7/bits/stl_uninitialized.h: 211)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/usr/include/c++/7/bits/stl_uninitialized.h: 215)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/usr/include/c++/7/bits/move.h: 48)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/usr/include/c++/7/bits/stl_construct.h: 75)
PGCC-F-0008-Error limit exceeded (/usr/include/c++/7/bits/stl_construct.h: 75)
PGCC/x86-64 Linux 19.4-0: compilation aborted
