I am trying to compile and build Unidata netcdf-c & netcdf-fortrand libraries using PGI compilers. The source code for these libraries are available at:
GitHub - Unidata/netcdf-c: Official GitHub repository for netCDF-C libraries and utilities.
GitHub - Unidata/netcdf-fortran: Official GitHub repository for netCDF-Fortran libraries, which depend on the netCDF C library. Install the netCDF C library first.
The first library (netcdf-c) compiles & build quite well using the following configure options:
./configure --prefix=/usr/local/netcdf/c \
CC=pgcc \
LDFLAGS=-L/usr/local/hdf5/lib \
CPPFLAGS="-I/usr/local/hdf5/include -fpic"
But when i try to compile the netCDF-fortran 4.4.2 libraries, using the following configuration options:
./configure --prefix=/usr/local/netcdf/fortran \
--disable-shared \
CC=pgcc \
CPPFLAGS="-I/usr/local/hdf5/include -fpic" \
FC=pgfortran \
F77=pgfortran \
The following is being prompted:
pgfortran -DHAVE_CONFIG_H -I. -I.. -I../libsrc -I/usr/local/hdf5/include -fpic -I../fortran -I../fortran -g -c -o test_write.o test_write.F
pgfortran -DHAVE_CONFIG_H -I. -I.. -I../libsrc -I/usr/local/hdf5/include -fpic -I../fortran -I../fortran -g -c -o util.o util.F
source='f03lib.c' object='f03lib.o' libtool=no \
DEPDIR=.deps depmode=pgcc /b in/sh ../depcomp \
pgcc -DHAVE_CONFIG_H -I. -I.. -I../libsrc -I/usr/local/hdf5/include -fpic -g -DLONGLONG_IS_LONG -c -o f03lib.o f03lib.c
/bin/sh ../libtool --tag=F77 --mode=link pgfortran -I../fortran -I../fortran -g -L/usr/local/hdf5/lib -o nf_test f03lib_f_interfaces.o test_get.o test_put.o nf_error.o nf_test.o test_read.o test_write.o util.o f03lib.o ../fortran/libnetcdff.la -lnetcdf
libtool: link: pgfortran -I../fortran -I../fortran -g -o nf_test f03lib_f_interfaces.o test_get.o test_put.o nf_error.o nf_test.o test_read.o test_write.o util.o f03lib.o -L/usr/local/hdf5/lib ../fortran/.libs/libnetcdff.a /usr/local/lib/libnetcdf.a
../fortran/.libs/libnetcdff.a(nf_control.o): In function `nf_inq_path_':
/tmp/netcdf-fortran-4.4.2/fortran/./nf_control.F90:307: undefined reference to `nc_inq_path'
Makefile:1251: recipe for target 'nf_test' failed
make[2]: *** [nf_test] Error 2
make[2]: Leaving directory '/tmp/netcdf-fortran-4.4.2/nf_test'
Makefile:1825: recipe for target 'check-am' failed
make[1]: *** [check-am] Error 2
make[1]: Leaving directory '/tmp/netcdf-fortran-4.4.2/nf_test'
Makefile:544: recipe for target 'check-recursive' failed
make: *** [check-recursive] Error 1
Also please notice a warning message prompted by libtool:
/bin/sh ../libtool --tag=FC --mode=link pgfortran -g -version-number 6:0:1 -L/usr/local/hdf5/lib -L/tmp/netcdf-fortran-4.4.2/fortran/.libs/ -o libnetcdff.la -rpath /usr/local/netcdf/fortran/lib typeSizes.lo module_netcdf_nc_data.lo module_netcdf_nc_interfaces.lo module_netcdf_nf_data.lo module_netcdf_nf_interfaces.lo module_netcdf_f03.lo nf_attio.lo nf_control.lo nf_dim.lo nf_misc.lo nf_genatt.lo nf_geninq.lo nf_genvar.lo nf_vario.lo nf_var1io.lo nf_varaio.lo nf_varmio.lo nf_varsio.lo netcdf.lo netcdf3_file.lo nf_v2compat.lo module_netcdf_fortv2_c_interfaces.lo nf_fortv2.lo -lnetcdf
libtool: link: ar cru .libs/libnetcdff.a typeSizes.o module_netcdf_nc_data.o module_netcdf_nc_interfaces.o module_netcdf_nf_data.o module_netcdf_nf_interfaces.o module_netcdf_f03.o nf_attio.o nf_control.o nf_dim.o nf_misc.o nf_genatt.o nf_geninq.o nf_genvar.o nf_vario.o nf_var1io.o nf_varaio.o nf_varmio.o nf_varsio.o netcdf.o netcdf3_file.o nf_v2compat.o module_netcdf_fortv2_c_interfaces.o nf_fortv2.o
ar: `u' modifier ignored since `D' is the default (see `U')
libtool: link: ranlib .libs/libnetcdff.a
libtool: link: ( cd ".libs" && rm -f "libnetcdff.la" && ln -s "../libnetcdff.la" "libnetcdff.la" )
ar: u' modifier ignored since D’ is the default (see `U’)
Would you please give me some idea to solve this issue?
Best Regards,
Néstor Waldyd
