I have a fortran code to simulate magnetic systems and I am trying to calculate the GPU speedup. I am compiling my code for the gpu using
pgfortran -fast -O3 -g -ta=nvidia:{cuda3.1,fastmath} -Minfo mycode.f90
and for the CPU, I am compiling with:
pgfortran -fast -O3 -g -Minfo mycode.f90
I am wondering if the speedup calculation will be correct in this case? Is there a flag that I need to use when compiling for the CPU that will be equivalent to “fastmath”.
Thanks,
Amin
Hi Amin,
If you are using sin, cos, divides, sqrt, or inverse sqrt, you can add the “-Mfprelaxed” flag. This will use faster but less accurate versions of these operations.
The is also the “-Mfpapprox” flag that uses hardware approximation. However, the accuracy is extremely poor so it’s use not generally advisable.
