during my tests to use CUDA in C# implementations I’m using the driver API to have better access to the compiled .cubin file.
As you write in your documentation there is a method to get the kernel function-pointer by name. The problem is, that the name is not fix in the cubin file and changes everytime a parameter or a code has changed. Is there a way to keep the name of the function constant so that I can rely on the function name?
Martin
