When I compile a kernel with nvcc -cubin the names of the resulting functions in the module always look like Z10testKerneliiPfjS_S. Can I avoid this by using some compiler option or do I have to change it manually?
Thanks in advance!
Thanks in advance!
I guess that was done for a purpose. There are alot of autogenerated stubs e.t.c all have to have different names.
Also, I haven’t seen such option in documentation.
Put
extern “C”
before your kernel function definition.
For example,
extern “C”
global void your_function(…)
Thanks a lot. It works! :)
