concurrent kernels
Hi, I am trying to speed up my apllication through concurrent kernel execution. I am using an GTX 580, by when I increase the kernel number it will be slower. Has anybody an idea? Hier is my awful code :-)
int nkernels = 8;
    int tile = N/nkernels;
    int offset = blocks/nkernels;
    int nstreams = nkernels + 1;
    dim3 dimBlock(threads,1,1);
    dim3 dimGrid(offset,1,1);
cudaStream_t *streams = (cudaStream_t*) malloc(nstreams * sizeof(cudaStream_t));
      for(int i = 0; i < nstreams; i++)
          cudaStreamCreate(&(streams[i]));
cudaEvent_t *kernelEvent;
    kernelEvent = (cudaEvent_t*) malloc(nkernels * sizeof(cudaEvent_t));
    for(int i = 0; i < nkernels; i++)
       cudaEventCreateWithFlags(&(kernelEvent[i]), cudaEventDisableTiming);
for(int i = 0; i<nkernels; i++)
      //reduction of one 1D array to an aarray of size(blocksize) final reduction on CPU
      reduceKernel <<< dimGrid, dimBlock, 0, streams[i] >>> (&d_idata[(i*tile)], &d_odata[offset*i], tile );
      cudaEventRecord(kernelEvent[i], streams[i]);
      cudaStreamWaitEvent( streams[ nstreams-1 ], kernelEvent[i],0);
// release resources
    for(int i = 0; i < nkernels; i++) {
        cudaStreamDestroy(streams[i]);
        cudaEventDestroy(kernelEvent[i]);
    free(streams);
    free(kernelEvent);
cudaMemcpy(h_tmp, d_odata, blocks*sizeof(computetype), cudaMemcpyDeviceToHost);
The result is fine but, computetime is slower than using one kernel launch.
It doesn’t make sense to launch multiple copies of the same kernel if you can just do one big kernel launch… there’s an overhead on each launch, so why would you want to keep paying it? If you can overlap transfers to and from the GPU with kernels, that would help the overall wall time. Also, if you had a bunch of different small kernels, none of which could keep the GPU occupied, then it might make sense to try having more than one kernel active at once. But if you can do everything in one kernel, why wouldn’t you?
Thanks for your answer,
I understand my error in reasoning. I try to overlap my kernels now.
