Concurrent Kernel execution overhead
Well, i’m new to cuda and testing with concurrent kernel execution! But for know my results are insatisfatory…
As a simple example i have created a kernel that does the following!!!
__global__ void Teste(int *A)
	int idx = blockIdx.x*blockDim.x + threadIdx.x;
	__shared__ int kk[nelement];
	kk[threadIdx.x] = idx*idx;
	for(int i=0;i<nelement;i++)
	__syncthreads();        // it doesn't matter it is only to keep it a little busy
	A[idx] = kk[threadIdx.x];
after this i’ve created n streams where n is variable and depends on the test purpose.
So the host code for this is…
#include "cuda.h"
#include "stdio.h"
#define nKern 1
#define nelement 32
int *a_d;
	int *a_h;
	cudaStream_t *streams = (cudaStream_t*) malloc((nKern+1) * sizeof(cudaStream_t));
	cudaMallocHost((void **)&a_h,nKern*sizeof(int)*nelement);
	cudaMalloc((void **)&a_d, sizeof(int) * nelement * nKern);
    	for(int i = 0; i < nKern+1; i++)
        	cudaStreamCreate(&(streams[i]));
	cudaEvent_t start_event, stop_event;
        cudaEventCreate(&start_event) ;
	cudaEventCreate(&stop_event) ;
	cudaEventRecord(start_event, 0);
	cudaEvent_t *kernelEvent;
	kernelEvent = (cudaEvent_t*) malloc(nKern * sizeof(cudaEvent_t));
	for(int i = 0; i < nKern; i++)
        cudaEventCreateWithFlags(&(kernelEvent[i]), cudaEventDisableTiming);
	for(int i=0; i < nKern; i++ )
		Teste <<< 1,nelement, 0, streams[i] >>> (&a_d[i*nelement]);
		cudaEventRecord(kernelEvent[i], streams[i]);
		cudaStreamWaitEvent(streams[nKern], kernelEvent[i],0);
	float elapsed_time;
	cudaMemcpyAsync(a_h,a_d,nKern*sizeof(int)*nelement,cudaMemcpyDeviceToHost, streams[nKern]);
	cudaEventRecord(stop_event, 0) ;
	cudaEventSynchronize(stop_event) ;
    	cudaEventElapsedTime(&elapsed_time, start_event, stop_event) ;
	for(int i=0; i< nelement*nKern;i++)
		printf(" %d \n",a_h[i] );
	for(int i = 0; i < nKern; i++) {
		cudaStreamDestroy(streams[i]);
		cudaEventDestroy(kernelEvent[i]);
	printf("%f ms \n", elapsed_time);
    	cudaEventDestroy(start_event);
    	cudaEventDestroy(stop_event);
    	cudaFreeHost(a_h);
    	cudaFree(a_d);
	free(streams);
    	cudaThreadExit();
One thing that i don’t understand is why when setting different nKern’s (1…15) (i have a GTX480 in Opensuse 11.3 (64 bit)) i get different execution times…
So i will aprecciate if anyone could explain why i don’t get the same execution time for nKern = 1 and nKern = 2…15?
best regards
Bruno Faria
As you are doubling the number of kernel you are also doubling the memory accesses that need to be shared with other kernels. Hence you will see that the computing time will gradually increase with the number of kernels.
Before anything else thanks for your fast repply!
I do understand what you have said but in a case where only shared memory is used shouldn’t the kernels times be equal? I’m thinking this because as each SM has it’s on shared memory resource!
Thanks in advance
Bruno Faria
I believe your kernel is far too short to run several in parallel. You are basically just measuring the setup overhead for kernel invocation. Do some real work in each kernel so that it runs for several milliseconds at least (better for a second so that you can see results already without measurement) and does not finish before the second kernel starts.
Yes that kernel is too short, but it is just a small example that i’ve mounted to better understand concurrent kernels!
I’ve been creating a project that uses interaction between two different kinds of particles! In that project i have a mechanism that arranjes the particle interactions, but it is limited to a block! So i thought to myself why not use concurrent kernels to make many indenpedent samples of interactions! In that context i have tested the system with streams and without streams! The streams versions only gives 1.5x of improvement!
So if i have created the little version above to see what happens! In that context i’m asking your help because in my project everything is independent and the memory used is primarly shared!
Thanks for you help!
Bruno Faria
