Inconsistent CUDA Kernel Execution Times in Sequential Execution
Hi all,
I’ve encountered an issue with inconsistent execution times when running a simple CUDA kernel sequentially in a single process. Specifically, I’m performing a basic vector addition (A + B = C). The first execution takes about 10ms, but the second execution shows an almost 0ms execution time. I suspect that the kernels are somehow being launched simultaneously, despite my intention to execute them sequentially.
To illustrate, if I run two kernels with execution times of 10ms and 15ms respectively, the second one incorrectly reports an execution time of 5ms when executed sequentially.
Here are the details of my setup:
  • CUDA Version: 12.5
  • Array Size: 50* 1024* 1024
  • Threads Per Block: 1024
  • Blocks Per Grid: Calculated based on array size and threads per block
Below is the full code:
#include <iostream>
#include <iomanip>
#include <chrono>
#include <thread>
#include <assert.h>
#include <vector>
#include <stdio.h>
#include <string.h>
#include <time.h>
#include <cuda.h>
#include <cuda_runtime.h>
static inline void checkDrvError(CUresult res, const char *tok, const char *file, unsigned line) {
    if (res != CUDA_SUCCESS) {
        const char *errStr = NULL;
        (void)cuGetErrorString(res, &errStr);
        std::cerr << file << ':' << line << ' ' << tok << "failed (" << (unsigned)res << "): " << errStr << std::endl;
#define CHECK_DRV(x) checkDrvError(x, #x, __FILE__, __LINE__);
typedef std::chrono::nanoseconds ReportingDuration;
#define CHECK_CUDA(ans) {check_cuda((ans), __FILE__, __LINE__);}
inline void check_cuda(int code, const char *file, int line, bool abort=true) {
    if (code != 0) {
        fprintf(stderr, "[customHook][%s:%3d]:CUDAERROR: %d\n", file, line, code);
        if (abort) exit(code);
__global__ void add(int *a, int *b, int *c, int nElements) {
    int i = blockDim.x * blockIdx.x + threadIdx.x;
    if (i < nElements) {
        c[i] = a[i] + b[i];
double what_time_is_it_now() {
    struct timespec time;
    if (clock_gettime(CLOCK_MONOTONIC, &time) == -1) exit(-1);
    return (double)time.tv_sec + (double)time.tv_nsec * 0.000000001;
int main() {
    size_t array_size = 50*1024*1024;
    int nElements = array_size / sizeof(int);
    int *A, *B, *C;
    int threadsPerBlock = 1024;
    int blocksPerGrid = (nElements + threadsPerBlock - 1) / threadsPerBlock;
    double start, end;
    assert(array_size % (2*1024*1024) == 0);
    CHECK_CUDA(cudaMalloc(&A, array_size));
    CHECK_CUDA(cudaMalloc(&C, array_size));
    CHECK_CUDA(cudaMalloc(&B, array_size));
    // Fill up the A & B
    int *host_A, *host_B;
    host_A = (int *)malloc(array_size);
    host_B = (int *)malloc(array_size);
    for (int i = 0; i < nElements; i++) {
        host_A[i] = 2;
        host_B[i] = 4;
    CHECK_CUDA(cudaMemcpy(A, host_A, array_size, cudaMemcpyHostToDevice));
    CHECK_CUDA(cudaMemcpy(B, host_B, array_size, cudaMemcpyHostToDevice));
    start = what_time_is_it_now();
    add<<<blocksPerGrid, threadsPerBlock>>>(A, B, C, nElements);
    end = what_time_is_it_now();
    printf("VectorAdd: %.4fms\n", (end - start) * 1000);
    add<<<blocksPerGrid, threadsPerBlock>>>(B, C, A, nElements);
    return 0;
Questions:
  1. Why does the second kernel execution report a much shorter execution time?
  2. Is there a possible overlap or concurrency issue with the kernel launches?
  3. How can I ensure that the kernels execute sequentially and measure their execution times accurately?
Any insights or suggestions would be greatly appreciated.
Thanks in advance!
Kernel launches are asynchronous with respect to the cpu. This means the cpu does not block automatically until the kernel is finished. That is why your current timing code only measures the time it takes to submit the kernel launch. It does not measure the execution time of the kernels.
You need to explicitly wait for kernel completion, for example using cudaDeviceSychronize();
    CHECK_CUDA(cudaDeviceSynchronize());
Hi @striker159,
Thank you for your advice. I tried incorporating cudaDeviceSynchronize() into my code, but I am still experiencing the same issue. Additionally, if cudaDeviceSynchronize() was the problem, I would expect the first execution time to also be almost 0ms. However, the first execution time is measured correctly, and only the second execution shows an incorrect, significantly reduced time.
Any other thoughts?
(1) make sure you compile for the architecture of the GPU you intend to run on, otherwise the first kernel invocation will incur JIT-compilation overhead
(2) make sure the GPU is idle before recording start time
(3) run the kernel more than two times. There are various “cold-start” effects that can affect the first few invocations of a kernel. You would want to reach “steady state” where kernel runtimes stabilize.
(4) especially for kernels whose performance is bound by memory throughput, it is common to encounter a significant amount of “noise” in execution measurements. It is impossible to recreate the exact same HW state for each kernel invocation, and small differences in initial state of the memory hierarchy can cause noticeable run-time differences (butterfly effect). A useful heuristic is to run such a kernel ten times, then report the fastest time measured.
Here is how I changed your code:
    for (int i = 0; i < 10; i++) {
        cudaDeviceSynchronize(); // wait until previous work complete
        cudaDeviceSynchronize(); // wait until kernel complete
Representative sample output on my system looks like so:
 VectorAdd: 0.6592ms
 VectorAdd: 0.4921ms
 VectorAdd: 0.8597ms
 VectorAdd: 0.7317ms
 VectorAdd: 0.7215ms  <<< steady state reached
 VectorAdd: 0.7245ms
 VectorAdd: 0.7214ms
 VectorAdd: 0.7287ms
 VectorAdd: 0.7231ms
 VectorAdd: 0.7201ms
It appears that steady state is reached after the first four iterations.
nowadays, its expected that the first kernel launch for a particular kernel will take significantly longer than subsequent launches for that kernel. There were factors that influence that prior to CUDA 12.2, but since CUDA 12.2, lazy loading is another factor that contributes to this significantly.
You could also measure kernel execution time with a profiler (Compute Nsight) to better know, what is going on and compare those results with yours.
