Getting Different Execution Times of Running Same Kernel Twice
I am getting different timings (shown as bold in the results below) of the same kernel when executed twice, any idea why this happens?
Results:
hepta iterations = 172, err = 774.110537
CPU Execution time: 4943.710000 ms
cuda hepta iterations = 172, err = 774.110537
GPU Execution time: 200.432632 ms
Correct!
GPU second Execution time: 170.358490 ms
Correct!
Following is the code snippet for kernel execution:
TYPE *b, *A_hepta, *x_hepta, *x_hepta_cuda;
cudaCheck(cudaMallocManaged(&A_hepta, n * 7 * sizeof(TYPE)), __LINE__);
cudaCheck(cudaMallocManaged(&b, n * sizeof(TYPE)), __LINE__);
x_hepta = (TYPE*) malloc(n * sizeof(TYPE));
cudaCheck(cudaMallocManaged(&x_hepta_cuda, n * sizeof(TYPE)), __LINE__);
init(A_hepta, b, x_hepta, x_hepta_cuda, n);
int deviceID;
cudaGetDevice(&deviceID);
cudaCheck(cudaMemPrefetchAsync(A_hepta, n * 7 * sizeof(TYPE), deviceID));
cudaCheck(cudaMemPrefetchAsync(b, n * sizeof(TYPE), deviceID));
cudaCheck(cudaMemPrefetchAsync(x_hepta_cuda, n * sizeof(TYPE), deviceID));
struct timeval start, end;
nvtxRangePushA("bicgstab_hepta");
gettimeofday(&start, NULL);
bicgstab_hepta(A_hepta, b, x_hepta, n);
gettimeofday(&end, NULL);
double elapsedTime = (end.tv_sec - start.tv_sec) * 1000.0; // sec to ms
elapsedTime += (end.tv_usec - start.tv_usec) / 1000.0; // us to ms
nvtxRangePop();
printf("CPU Execution time: %.6f ms\n", elapsedTime);
cudaEvent_t cuda_start, cuda_stop;
cudaEventCreate(&cuda_start);
cudaEventCreate(&cuda_stop);
float milliseconds = 0;
nvtxRangePushA("bicgstab_hepta_cuda");
cudaEventRecord(cuda_start);
**bicgstab_hepta_cuda(A_hepta, b, x_hepta_cuda, n);**
cudaCheck(cudaDeviceSynchronize(), __LINE__);
cudaEventRecord(cuda_stop);
cudaEventSynchronize(cuda_stop);
milliseconds = 0;
cudaEventElapsedTime(&milliseconds, cuda_start, cuda_stop);
nvtxRangePop();
printf("GPU Execution time: %.6f ms\n", milliseconds);
check_result(x_hepta, x_hepta_cuda, n);
//Reallocate and ReInitialize CUDA Memories
cudaFree(A_hepta);
cudaFree(b);
cudaFree(x_hepta_cuda);
init(A_hepta, b, x_hepta, x_hepta_cuda, n, GPU_INIT);
nvtxRangePushA("bicgstab_hepta_second");
milliseconds = 0;
nvtxRangePop();
printf("GPU second Execution time: %.6f ms\n", milliseconds);
cudaEventDestroy(cuda_start);
cudaEventDestroy(cuda_stop);
free(x_hepta);
cudaFree(A_hepta);
cudaFree(b);
This is a perfectly normal observation. A best practice of benchmarking is to never measure anything on the first pass, when hardware and software structures (e.g. caches and buffers of various sorts) are “cold”. Instead, run a few “warmup” passes first, then measure performance once the system has reached “steady state”.
Some benchmarks use a simple approach of running the code under test ten times and then report the timing of the fastest pass. In my experience, this is particularly useful for memory-intensive workloads that tend to have the widest variations run-to-run. Another simple approach is to run three passes, with two serving as warmup while the timing of the third pass is reported. That can work well for simple codes, but in my experience steady state is no always reached with two warmup passes.
So you may need to experiment a bit to see how many passes are needed before steady state is reached.
