Configure: error: Python libs not found. Windows requires Python modules to be explicitly linked to libpython. configure failed
I am using deepstream 6.1(samples) docker, and trying to install the gst-python. while running the command
./autogen.sh PYTHON=python3
The output
+ Setting up common submodule
Submodule 'common' (https://gitlab.freedesktop.org/gstreamer/common.git) registered for path 'common'
Cloning into '/opt/nvidia/deepstream/deepstream-6.1/gst-python/common'...
Submodule path 'common': checked out '59cb678164719ff59dcf6c8b93df4617a1075d11'
+ passing argument PYTHON=python3 to configure
+ options passed to configure:  PYTHON=python3
+ check for build tools
  checking for autoreconf ...
/usr/bin/autoreconf
  checking for pkg-config ...
/usr/bin/pkg-config
aclocal: warning: couldn't open directory 'm4': No such file or directory
libtoolize: putting auxiliary files in '..'.
libtoolize: copying file '../ltmain.sh'
libtoolize: putting macros in 'm4'.
libtoolize: copying file 'm4/libtool.m4'
libtoolize: copying file 'm4/ltoptions.m4'
libtoolize: copying file 'm4/ltsugar.m4'
libtoolize: copying file 'm4/ltversion.m4'
libtoolize: copying file 'm4/lt~obsolete.m4'
libtoolize: Consider adding 'AC_CONFIG_MACRO_DIRS([m4])' to configure.ac,
libtoolize: and rerunning libtoolize and aclocal.
configure.ac:47: installing './compile'
configure.ac:10: installing './config.guess'
configure.ac:10: installing './config.sub'
configure.ac:13: installing './install-sh'
configure.ac:47: error: required file './ltmain.sh' not found
configure.ac:13: installing './missing'
Makefile.am: installing './INSTALL'
gi/overrides/Makefile.am: installing './depcomp'
gi/overrides/Makefile.am:7: installing './py-compile'
plugin/Makefile.am:3: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
autoreconf: automake failed with exit status: 1
root@2556eb6f1003:/opt/nvidia/deepstream/deepstream-6.1/gst-python# apt-get install python3-dev libpython3-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
  libexpat1-dev libpython3.8 libpython3.8-dev python3.8-dev
The following NEW packages will be installed:
  libexpat1-dev libpython3-dev libpython3.8 libpython3.8-dev python3-dev python3.8-dev
0 upgraded, 6 newly installed, 0 to remove and 16 not upgraded.
Need to get 6216 kB of archives.
After this operation, 27.0 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libexpat1-dev amd64 2.2.9-1ubuntu0.4 [117 kB]
Get:2 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libpython3.8 amd64 3.8.10-0ubuntu1~20.04.4 [1625 kB]
Get:3 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libpython3.8-dev amd64 3.8.10-0ubuntu1~20.04.4 [3952 kB]
Get:4 http://archive.ubuntu.com/ubuntu focal/main amd64 libpython3-dev amd64 3.8.2-0ubuntu2 [7236 B]
Get:5 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 python3.8-dev amd64 3.8.10-0ubuntu1~20.04.4 [514 kB]
Get:6 http://archive.ubuntu.com/ubuntu focal/main amd64 python3-dev amd64 3.8.2-0ubuntu2 [1212 B]
Fetched 6216 kB in 3s (2307 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libexpat1-dev:amd64.
(Reading database ... 30217 files and directories currently installed.)
Preparing to unpack .../0-libexpat1-dev_2.2.9-1ubuntu0.4_amd64.deb ...
Unpacking libexpat1-dev:amd64 (2.2.9-1ubuntu0.4) ...
Selecting previously unselected package libpython3.8:amd64.
Preparing to unpack .../1-libpython3.8_3.8.10-0ubuntu1~20.04.4_amd64.deb ...
Unpacking libpython3.8:amd64 (3.8.10-0ubuntu1~20.04.4) ...
Selecting previously unselected package libpython3.8-dev:amd64.
Preparing to unpack .../2-libpython3.8-dev_3.8.10-0ubuntu1~20.04.4_amd64.deb ...
Unpacking libpython3.8-dev:amd64 (3.8.10-0ubuntu1~20.04.4) ...
Selecting previously unselected package libpython3-dev:amd64.
Preparing to unpack .../3-libpython3-dev_3.8.2-0ubuntu2_amd64.deb ...
Unpacking libpython3-dev:amd64 (3.8.2-0ubuntu2) ...
Selecting previously unselected package python3.8-dev.
Preparing to unpack .../4-python3.8-dev_3.8.10-0ubuntu1~20.04.4_amd64.deb ...
Unpacking python3.8-dev (3.8.10-0ubuntu1~20.04.4) ...
Selecting previously unselected package python3-dev.
Preparing to unpack .../5-python3-dev_3.8.2-0ubuntu2_amd64.deb ...
Unpacking python3-dev (3.8.2-0ubuntu2) ...
Setting up libexpat1-dev:amd64 (2.2.9-1ubuntu0.4) ...
Setting up libpython3.8:amd64 (3.8.10-0ubuntu1~20.04.4) ...
Setting up libpython3.8-dev:amd64 (3.8.10-0ubuntu1~20.04.4) ...
Setting up python3.8-dev (3.8.10-0ubuntu1~20.04.4) ...
Setting up libpython3-dev:amd64 (3.8.2-0ubuntu2) ...
Setting up python3-dev (3.8.2-0ubuntu2) ...
Processing triggers for libc-bin (2.31-0ubuntu9.7) ...
root@2556eb6f1003:/opt/nvidia/deepstream/deepstream-6.1/gst-python# ./autogen.sh PYTHON=python3
/usr/bin/autoreconf
/usr/bin/pkg-config
libtoolize: putting auxiliary files in '.'.
libtoolize: copying file './ltmain.sh'
+ running configure ...
  default flags:  --enable-maintainer-mode --enable-gtk-doc
  external flags:  PYTHON=python3
./configure --enable-maintainer-mode --enable-gtk-doc PYTHON=python3
configure: WARNING: unrecognized options: --enable-gtk-doc
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether UID '0' is supported by ustar format... yes
checking whether GID '0' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking nano version... 0 (release)
checking whether to enable maintainer-specific portions of Makefiles... yes
checking whether make supports nested variables... (cached) yes
checking how to print strings... printf
checking whether make supports the include directive... yes (GNU style)
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /usr/bin/dd
checking how to truncate binary pipes... /usr/bin/dd bs=4096 count=1
checking for mt... no
checking if : is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... no
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking for gcc option to accept ISO C99... none needed
checking for gcc option to accept ISO Standard C... (cached) none needed
checking for python version... 3.8
checking for python platform... linux
checking for python script directory... ${prefix}/lib/python3.8/site-packages
checking for python extension module directory... ${exec_prefix}/lib/python3.8/site-packages
checking for python >= 2.7... checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for GST... yes
checking for PYGOBJECT... yes
okay
checking for headers required to compile python extensions... found
checking for pygobject overrides directory... ${exec_prefix}/lib/python3.8/site-packages/gi/overrides
configure: Using /usr/local/lib/gstreamer-1.0 as the plugin install location
checking for libraries required to embed python... no
configure: error: Python libs not found. Windows requires Python modules to be explicitly linked to libpython.
  configure failed
Did you follow the steps 1.1/1.2/1.3/1.4 form deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub ?
We have bug to track this issue, can you follow this to setup? deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
When I try to run the command inside the docker container:
apt install python3-gi python3-dev python3-gst-1.0 python-gi-dev git python-dev \
    python3 python3-pip python3.8-dev cmake g++ build-essential libglib2.0-dev \
    libglib2.0-dev-bin libgstreamer1.0-dev libtool m4 autoconf automake libgirepository1.0-dev libcairo2-dev
root@2556eb6f1003:/opt/nvidia/deepstream/deepstream-6.1# apt install python3-gi python3-dev python3-gst-1.0 python-gi-dev git python-dev     python3 python3-pip python3.8-dev cmake g++ build-essential libglib2.0-dev     libglib2.0-dev-bin libgstreamer1.0-dev libtool m4 autoconf automake libgirepository1.0-dev libcairo2-dev
Note, selecting 'python-dev-is-python2' instead of 'python-dev'
autoconf is already the newest version (2.69-11.1).
automake is already the newest version (1:1.16.1-4ubuntu6).
automake set to manually installed.
cmake is already the newest version (3.16.3-1ubuntu1).
g++ is already the newest version (4:9.3.0-1ubuntu2).
libtool is already the newest version (2.4.6-14).
m4 is already the newest version (1.4.18-4).
m4 set to manually installed.
python3 is already the newest version (3.8.2-0ubuntu2).
python3 set to manually installed.
python3-dev is already the newest version (3.8.2-0ubuntu2).
python3-gi is already the newest version (3.36.0-1).
python3-gi set to manually installed.
python-gi-dev is already the newest version (3.36.0-1).
build-essential is already the newest version (12.8ubuntu1.1).
git is already the newest version (1:2.25.1-1ubuntu3.4).
libglib2.0-dev is already the newest version (2.64.6-1~ubuntu20.04.4).
libglib2.0-dev-bin is already the newest version (2.64.6-1~ubuntu20.04.4).
python3.8-dev is already the newest version (3.8.10-0ubuntu1~20.04.4).
python3.8-dev set to manually installed.
  autopoint bsdmainutils curl debhelper dh-autoreconf dh-strip-nondeterminism dwz gettext gettext-base gir1.2-freedesktop gir1.2-gst-plugins-base-1.0 gir1.2-gstreamer-1.0 gobject-introspection groff-base gstreamer1.0-gl intltool-debian
  libarchive-cpio-perl libarchive-zip-perl libcairo-script-interpreter2 libcroco3 libdebhelper-perl libfile-stripnondeterminism-perl libfontconfig1-dev libfreetype-dev libfreetype6-dev libgraphene-1.0-0 libgstreamer-gl1.0-0 libice-dev
  libice6 liblzo2-2 libmail-sendmail-perl libpixman-1-dev libpng-dev libpng-tools libpython2-dev libpython2.7 libpython2.7-dev libsm-dev libsm6 libsub-override-perl libsys-hostname-long-perl libuchardet0 libxcb-render0-dev
  libxcb-shm0-dev libxext-dev libxrender-dev libyaml-0-2 man-db po-debconf python-pip-whl python2-dev python2.7-dev python3-mako python3-markdown python3-markupsafe python3-packaging python3-pkg-resources python3-pygments
  python3-pyparsing python3-setuptools python3-six python3-wheel python3-yaml x11proto-xext-dev
Suggested packages:
  wamerican | wordlist whois vacation dh-make gettext-doc libasprintf-dev libgettextpo-dev groff libcairo2-doc freetype2-doc libgirepository1.0-doc gstreamer1.0-doc libice-doc libsm-doc libxext-doc apparmor less www-browser
  libmail-box-perl python3-beaker python-mako-doc python-markdown-doc python-pygments-doc ttf-bitstream-vera python-pyparsing-doc python-setuptools-doc
  libarchive-cpio-perl libarchive-zip-perl libcairo-script-interpreter2 libcairo2-dev libcroco3 libdebhelper-perl libfile-stripnondeterminism-perl libfontconfig1-dev libfreetype-dev libfreetype6-dev libgirepository1.0-dev
  libgraphene-1.0-0 libgstreamer-gl1.0-0 libgstreamer1.0-dev libice-dev libice6 liblzo2-2 libmail-sendmail-perl libpixman-1-dev libpng-dev libpng-tools libpython2-dev libpython2.7 libpython2.7-dev libsm-dev libsm6 libsub-override-perl
  libsys-hostname-long-perl libuchardet0 libxcb-render0-dev libxcb-shm0-dev libxext-dev libxrender-dev libyaml-0-2 man-db po-debconf python-dev-is-python2 python-pip-whl python2-dev python2.7-dev python3-gst-1.0 python3-mako
  python3-markdown python3-markupsafe python3-packaging python3-pip python3-pkg-resources python3-pygments python3-pyparsing python3-setuptools python3-six python3-wheel python3-yaml x11proto-xext-dev
0 upgraded, 70 newly installed, 0 to remove and 16 not upgraded.
Need to get 161 kB/17.4 MB of archives.
After this operation, 77.2 MB of additional disk space will be used.
Ign:1 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 curl amd64 7.68.0-1ubuntu2.10
Err:1 http://security.ubuntu.com/ubuntu focal-updates/main amd64 curl amd64 7.68.0-1ubuntu2.10
  404  Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/c/curl/curl_7.68.0-1ubuntu2.10_amd64.deb  404  Not Found [IP: 91.189.91.39 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Output after the command:
apt-get update --fix-missing
root----------:/opt/nvidia/deepstream/deepstream-6.1# apt-get update --fix-missing
Get:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64  InRelease [1581 B]
Get:2 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64  Packages [580 kB]
Err:2 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64  Packages
  File has unexpected size (580845 != 580040). Mirror sync in progress? [IP: 152.199.39.144 443]
  Hashes of expected file:
   - Filesize:580040 [weak]
   - SHA256:dc8abbaf470d3ee626f4f1f4d2871a98d8dc8f770bc592676f0d1f60637e0c2d
   - SHA1:109bfa4e5c415731aa44b1c1caae3f19754c5406 [weak]
   - MD5Sum:bf8f928cb55b1c9e4c158a69ee52b5d8 [weak]
  Release file created at: Mon, 11 Jul 2022 19:01:54 +0000
Get:3 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Hit:4 http://archive.ubuntu.com/ubuntu focal InRelease
Get:5 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:6 http://archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB]
Get:7 http://security.ubuntu.com/ubuntu focal-security/main amd64 Packages [1990 kB]
Get:8 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [2454 kB]
Get:9 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages [27.5 kB]
Get:10 http://security.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [1351 kB]
Get:11 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages [883 kB]
Get:12 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [30.2 kB]
Get:13 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [1161 kB]
Get:14 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [1483 kB]
Get:15 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 Packages [27.1 kB]
Get:16 http://archive.ubuntu.com/ubuntu focal-backports/main amd64 Packages [54.2 kB]
Fetched 9797 kB in 2s (4269 kB/s)
E: Failed to fetch https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/Packages.gz  File has unexpected size (580845 != 580040). Mirror sync in progress? [IP: 152.199.39.144 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
You may need to reinstall.
I deleted the current docker container and followed from the start, but still I end up with the same error.
It’s your system issue, we can download the docker successfully. please try to solve it.
