Fail to install gst-python in deepstream6.1 docker
• Hardware Platform GPU)
• DeepStream Version 6.1
• Issue Type questions
Hi there
While I’m trying to use the latest deepstream docker, I fail to install gst-python inside the docker. After I exec the command ./autogen.sh PYTHON=python3, it fails and report this:
checking for headers required to compile python extensions... found
checking for pygobject overrides directory... ${exec_prefix}/lib/python3.8/site-packages/gi/overrides
checking for GST... yes
configure: Using /usr/local/lib/gstreamer-1.0 as the plugin install location
checking for PYGOBJECT... yes
checking for libraries required to embed python... no
configure: error: Python libs not found. Windows requires Python modules to be explicitly linked to libpython.
  configure failed
I searched and it said it is because python 3.8 is no longer together with --embed. there are discussions about this 1 and 2.
btw, the 6.0.1 image with python 3.6 works fine on my pc.
appreciate if there is any advice.
Please use this,
./autogen.sh
Thanks for the quick reply, I solved this problem just now.
The root problem as I mentioned before, is python3.8is no longer linked to libpython. And the solution is to modify the acinclude.m4 file. I found it here.
I don’t try with single deepstream sdk, I do all my work using docker. I guess it is better to add this somewhere?
