Confusion about calculating net-scale-factor and offset
could you give an example about how to calculate net-scale-factor, the formular is an abstract concept.
for example, the net is normalized(mean=[0.485, 0.456, 0.406],std=[0.229, 0.224, 0.225]). How to compute net scale factor and offsets?
• DeepStream Version
• TensorRT Version
NVIDIA Developer Forums
Accelerated ComputingIntelligent Video AnalyticsDeepStream SDK
Categories
  • profile, messages, bookmarks and preferences
Home
3
3
user70013
1h
Reply
  • created
1h
last reply
](Confusion about calculating net-scale-factor and offset - #4 by fanzh)
38m
  • 2
replies
  • 7
views
  • 2
users
user70013
1h
SolutionReply
fanzhModerator
38m
• Hardware Platform :GPU
• DeepStream Version:6.1
• TensorRT Version:8.2.5.1
• Issue Type:new questions
• How to reproduce the issue ?
i don’t know how to calculate net-scale-factor and offsets, the formular is an abstract concept, could you give a example with calculating offsets and net-scale-factor
• Requirement details
i don’t know how to calculate net-scale-factor and offsets, the formular is an abstract concept, could you give a example with calculating offsets and net-scale-factor. the
describe is easily,could you give a detail description, thanks.
[property]
net-scale-factor=0.0175
offsets=77.5;21.2;11.8
model-engine-file=…/model/efficientNet.plan
labelfile-path=./effLabel.txt
force-implicit-batch-dim=1
batch-size=1
infer-dims=3;224;224
network-mode=0
process-mode=2
model-color-format=0
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0
network-type=1
output-blob-names=1065
classifier-async-mode=1
classifier-threshold=0.2
nvinfer plugin is opensource in DeepStream SDK, you can find net-scale-factor in the code, then check how it is used.
