A question regarding net-scale-factor and offsets
DS 7
dGPU
I’m successfully using a tandem of FaceNet (FaceDetect | NVIDIA NGC) running on PGIE for detection and an ArcFace ONNX model (open_model_zoo/models/public/face-recognition-resnet100-arcface-onnx/README.md at master · openvinotoolkit/open_model_zoo · GitHub) on SGIE for recognition. The latter model produces a 512 float fingerprint vector, which I compare to a database of fingerprints created earlier using Cosine similarity. That worked fine only, after I set a value of 1 for net-scale-factor for the SGIE config and providing nothing special for `offset´.
For the first time in all my attempts using different models I’m having nearly no ambiguities in the recognition results.
Is there any means for knowing, what these values should be ideally for this ONNX model?
[property]
#net-scale-factor=0.0039215697906911373
net-scale-factor=1
#offsets=123.675;116.28;103.53
These two parameters are the normalization parameters for the preprocessing. Please refer to the second paragraph in Gst-nvinfer — DeepStream documentation 6.4 documentation
The value of the “net-scale-factor” and “offsets” are decided by the preprocessing algorithm used in the model training. Please consult the engineer who trained the model.
