The course uses NeMo services. I get an error each time I attempt to complete my course. It is urgent since I lose tomorrow.
import os
from nemollm.api import NemoLLM
from llm_utils.nemo_service_models import NemoServiceBaseModel
api_key = os.getenv(‘NGC_API_KEY’)
api_host = os.getenv(‘API_HOST’)
conn = NemoLLM(
** api_host=api_host,**
** api_key=api_key**
response = conn.list_models()
models = {}
for model in response[‘models’]:
name = model.get(‘name’)
features = model.get(‘features’)
models[name] = features
ServerSideError Traceback (most recent call last)
Cell In[4], line 1
----> 1 response = conn.list_models()
2 models = {}
4 for model in response[‘models’]:
File /usr/local/lib/python3.12/site-packages/nemollm/api.py:139, in NemoLLM.list_models(self)
136 _thread_context.session = create_session()
138 response = _thread_context.session.get(url, headers=self.headers, timeout=REQUESTS_TIMEOUT_SECS)
→ 139 NemoLLM.handle_response(response)
140 return response.json()
File /usr/local/lib/python3.12/site-packages/nemollm/api.py:130, in NemoLLM.handle_response(response, stream)
126 raise ClientSideError(status_code=status_code, reason=response.reason, decoded_content=decoded_content)
128 # server side errors
129 else:
→ 130 raise ServerSideError(status_code=status_code, reason=response.reason, decoded_content=decoded_content)
ServerSideError: Request failed with HTTP Status Code 500 INTERNAL SERVER ERROR Solution: Server is unable to handle your request right now. Please retry your request after a brief wait. If this problem persist, please contact NeMo LLM team Full response:
requests.exceptions.ConnectTimeout: HTTPSConnectionPool(host='api.llm.ngc.nvidia.com', port=443): Max retries exceeded with url: /v1/models (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f9fc82cbf50>, 'Connection to api.llm.ngc.nvidia.com timed out. (connect timeout=None)')) // Werkzeug DebuggerConnectTimeout
File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 196, in
_new_conn"""Establish a socket connection and set nodelay settings on it.:return: New socket connection."""try:sock = connection.create_connection(
(self._dns_host, self.port),self.timeout,source_address=self.source_address,socket_options=self.socket_options,)File "/usr/local/lib/python3.12/site-packages/urllib3/util/connection.py", line 85, in
create_connectionif sock is not None:sock.close()if err is not None:try:raise err ^^^^^^^^^
finally:# Break explicitly a reference cycleerr = Noneelse:raise OSError("getaddrinfo returns an empty list")File "/usr/local/lib/python3.12/site-packages/urllib3/util/connection.py", line 73, in
create_connectionif timeout is not _DEFAULT_TIMEOUT:sock.settimeout(timeout)if source_address:sock.bind(source_address)sock.connect(sa) ^^^^^^^^^^^^^^^^
# Break explicitly a reference cycleerr = Nonereturn sockexcept OSError as _:- The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 789, in
urlopen# it will also try to release it and we'll have a double-release# mess.response_conn = conn if not release_conn else None# Make the request on the HTTPConnection objectresponse = self._make_request(
conn,method,url,timeout=timeout_obj,body=body,File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 490, in
_make_request# then thereif isinstance(new_e, (OSError, NewConnectionError, TimeoutError, SSLError)) and (conn and conn.proxy and not conn.has_connected_to_proxy):new_e = _wrap_proxy_error(new_e, conn.proxy.scheme)raise new_e ^^^^^^^^^^^
# conn.request() calls http.client.*.request, not the method in# urllib3.request. It also calls makefile (recv) on the socket.try:conn.request(File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 466, in
_make_requestconn.timeout = Timeout.resolve_default_timeout(timeout_obj.connect_timeout)try:# Trigger any extra validation we need to do.try:self._validate_conn(conn) ^^^^^^^^^^^^^^^^^^^^^^^^^
except (SocketTimeout, BaseSSLError) as e:self._raise_timeout(err=e, url=url, timeout_value=conn.timeout)raise# _validate_conn() starts the connection to an HTTPS proxyFile "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 1095, in
_validate_conn"""super()._validate_conn(conn)# Force connect early to allow us to validate the connection.if conn.is_closed:conn.connect() ^^^^^^^^^^^^^^
# TODO revise this, see https://github.com/urllib3/urllib3/issues/2791if not conn.is_verified and not conn.proxy_is_verified:warnings.warn((File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 615, in
connectself.ca_cert_dir = ca_cert_dir and os.path.expanduser(ca_cert_dir)self.ca_cert_data = ca_cert_datadef connect(self) -> None:sock: socket.socket | ssl.SSLSocketself.sock = sock = self._new_conn() ^^^^^^^^^^^^^^^^
server_hostname: str = self.hosttls_in_tls = False# Do we need to establish a tunnel?if self._tunnel_host is not None:File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 205, in
_new_connsocket_options=self.socket_options,)except socket.gaierror as e:raise NameResolutionError(self.host, self, e) from eexcept SocketTimeout as e:raise ConnectTimeoutError( ^^^^^^^^
self,f"Connection to {self.host} timed out. (connect timeout={self.timeout})",) from eexcept OSError as e:- The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 667, in
sendpasselse:timeout = TimeoutSauce(connect=timeout, read=timeout)try:resp = conn.urlopen(
method=request.method,url=url,body=request.body,headers=request.headers,redirect=False,File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 843, in
urlopen) and (conn and conn.proxy and not conn.has_connected_to_proxy):new_e = _wrap_proxy_error(new_e, conn.proxy.scheme)elif isinstance(new_e, (OSError, HTTPException)):new_e = ProtocolError("Connection aborted.", new_e)retries = retries.increment(
method, url, error=new_e, _pool=self, _stacktrace=sys.exc_info()[2])retries.sleep()# Keep track of the error for the retry warning.File "/usr/local/lib/python3.12/site-packages/urllib3/util/retry.py", line 519, in
incrementhistory=history,)if new_retry.is_exhausted():reason = error or ResponseError(cause)raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
log.debug("Incremented Retry for (url='%s'): %r", url, new_retry)return new_retry- During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 1498, in
__call__) -> cabc.Iterable[bytes]:"""The WSGI server calls the Flask application object as theWSGI application. This calls :meth:`wsgi_app`, which can bewrapped to apply middleware."""return self.wsgi_app(environ, start_response) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 1476, in
wsgi_apptry:ctx.push()response = self.full_dispatch_request()except Exception as e:error = eresponse = self.handle_exception(e) ^^^^^^^^^^^^^^^^^^^^^^^^
except: # noqa: B001error = sys.exc_info()[1]raisereturn response(environ, start_response)finally:File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 1473, in
wsgi_appctx = self.request_context(environ)error: BaseException | None = Nonetry:try:ctx.push()response = self.full_dispatch_request() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^
except Exception as e:error = eresponse = self.handle_exception(e)except: # noqa: B001error = sys.exc_info()[1]File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 882, in
full_dispatch_requestrequest_started.send(self, _async_wrapper=self.ensure_sync)rv = self.preprocess_request()if rv is None:rv = self.dispatch_request()except Exception as e:rv = self.handle_user_exception(e) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
return self.finalize_request(rv)def finalize_request(self,rv: ft.ResponseReturnValue | HTTPException,File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 880, in
full_dispatch_requesttry:request_started.send(self, _async_wrapper=self.ensure_sync)rv = self.preprocess_request()if rv is None:rv = self.dispatch_request() ^^^^^^^^^^^^^^^^^^^^^^^
except Exception as e:rv = self.handle_user_exception(e)return self.finalize_request(rv)def finalize_request(File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 865, in
dispatch_requestand req.method == "OPTIONS"):return self.make_default_options_response()# otherwise dispatch to the handler for that endpointview_args: dict[str, t.Any] = req.view_args # type: ignore[assignment]return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args) # type: ignore[no-any-return] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
def full_dispatch_request(self) -> Response:"""Dispatches the request and on top of that performs requestpre and postprocessing as well as HTTP exception catching anderror handling.File "//app.py", line 40, in
proxy# Create a mutable copy of the headers, excluding certain headersheaders = {key: value for key, value in request.headers.items() if key not in ['Host', 'Content-Length']}headers['Authorization'] = f'Bearer {api_key}'headers['Accept'] = 'application/json' # Set Accept header to application/jsonresponse = requests.request(
method=request.method,url=url,headers=headers,data=request.get_data(),allow_redirects=False,File "/usr/local/lib/python3.12/site-packages/requests/api.py", line 59, in
request# By using the 'with' statement we are sure the session is closed, thus we# avoid leaving sockets open which can trigger a ResourceWarning in some# cases, and look like a memory leak in others.with sessions.Session() as session:return session.request(method=method, url=url, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
def get(url, params=None, **kwargs):
r"""Sends a GET request.File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 589, in
requestsend_kwargs = {"timeout": timeout,"allow_redirects": allow_redirects,}send_kwargs.update(settings)resp = self.send(prep, **send_kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
return respdef get(self, url, **kwargs):r"""Sends a GET request. Returns :class:`Response` object.File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 703, in
send# Start time (approximately) of the requeststart = preferred_clock()# Send the requestr = adapter.send(request, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
# Total elapsed time of the request (approximately)elapsed = preferred_clock() - startr.elapsed = timedelta(seconds=elapsed)File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 688, in
sendexcept MaxRetryError as e:if isinstance(e.reason, ConnectTimeoutError):# TODO: Remove this in 3.0.0: see #2811if not isinstance(e.reason, NewConnectionError):raise ConnectTimeout(e, request=request) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
if isinstance(e.reason, ResponseError):raise RetryError(e, request=request)if isinstance(e.reason, _ProxyError):
This is the Copy/Paste friendly version of the traceback.
Traceback (most recent call last): File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 196, in _new_conn sock = connection.create_connection( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/urllib3/util/connection.py", line 85, in create_connection raise err File "/usr/local/lib/python3.12/site-packages/urllib3/util/connection.py", line 73, in create_connection sock.connect(sa) TimeoutError: [Errno 110] Operation timed outThe above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 789, in urlopen
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 490, in _make_request
raise new_e
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 466, in _make_request
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 1095, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 615, in connect
File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 205, in _new_conn
urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPSConnection object at 0x7f9fc82cbf50>, 'Connection to api.llm.ngc.nvidia.com timed out. (connect timeout=None)')
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 667, in send
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 843, in urlopen
File "/usr/local/lib/python3.12/site-packages/urllib3/util/retry.py", line 519, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.llm.ngc.nvidia.com', port=443): Max retries exceeded with url: /v1/models (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7f9fc82cbf50>, 'Connection to api.llm.ngc.nvidia.com timed out. (connect timeout=None)'))
File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 1498, in call
File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 1476, in wsgi_app
File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 1473, in wsgi_app
File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 882, in full_dispatch_request
File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 880, in full_dispatch_request
File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 865, in dispatch_request
File "//app.py", line 40, in proxy
File "/usr/local/lib/python3.12/site-packages/requests/api.py", line 59, in request
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 688, in send
<div class="pin-prompt">
<div class="inner">
<h3>Console Locked</h3>
<p>
The console is locked and needs to be unlocked by entering the PIN.
You can find the PIN printed out on the standard output of your
shell that runs the server.
<form>
<p>PIN:
<input type=text name=pin size=14>
<input type=submit name=btn value="Confirm Pin">
</form>
</div>
</div>
