Connecting A5000 with NVSwitch
I have couple related questions to hardware, so I will combine them here:
  1. I have a DL server with 4 (four) A5000 in it. I have them connected with NVLink (2+2). I saw that DGX has the NVSwitch, which allows communication between all. I was wondering if this is possible to connect A5000 with NVSwitch? If yes, how do I do this?
  2. I’m about to purchase a new DL server and I want to pick optimal CPUs (AMD) for it. Is there a throughput table that I can look into in order to pick a correct CPU?
Thanks,
Nikolay.
It is not possible. NVSwitch has to be designed into the server platform itself, it’s not something you can add later.
Thanks, that what I thought about.
Do you have any info regarding to CPU matching for the GPUs?
Thanks,
No, I don’t really understand the question, so don’t have any response there.
Picking the CPU such that it won’t be a bottle neck. I saw that it should be at least 4 cores per GPU, but it sounds too little for IMO.
