I have some issues whiling using bluefiled2.I will appreciate if you can help on this to me.
I have two ubuntu machines, which I’ll call A and B for convenience.
A is equipped with a bluefield2-DPU, and B is equipped with a connectX-3 infiniband network card.
I connected A to the switch through the network adapter port on the DPU and B to the switch through the connectX-3 network adapter.Then I give the two ports IP addresses in the same subnet.
At this point I think A should be able to ping B,but it didn’t work out.
Here is part of my IP config on A
ens14f0np0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.111.8 netmask 255.255.255.0 broadcast 192.168.111.255
inet6 fe80::ba3f:d2ff:fe54:c116 prefixlen 64 scopeid 0x20
ether b8:3f:d2:54:c1:16 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 19 bytes 1366 (1.3 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
tmfifo_net0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.100.1 netmask 255.255.255.0 broadcast 192.168.100.255
inet6 fe80::21a:caff:feff:ff02 prefixlen 64 scopeid 0x20
ether 00:1a:ca:ff:ff:02 txqueuelen 1000 (Ethernet)
RX packets 99001 bytes 8496198 (8.4 MB)
TX packets 242575 bytes 332808453 (332.8 MB)
Here is part of my IP config on B
ibs3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 2044
inet 192.168.111.9 netmask 255.255.255.0 broadcast 192.168.111.255
inet6 fe80::ee0d:9a03:10:eb41 prefixlen 64 scopeid 0x20
unspec A0-00-02-20-FE-80-00-00-00-00-00-00-00-00-00-00 txqueuelen 256 (UNSPEC )
TX packets 21 bytes 1356 (1.3 KB)
The switch on the DPU also seems to be working properly
ubuntu@localhost:~/spdk$ sudo ovs-vsctl show
ad38f0a8-75fc-44e1-a1cc-fdc555eb7df3
Bridge ovsbr1
Port pf0hpf
Interface pf0hpf
Port p0
Interface p0
Port ovsbr1
Interface ovsbr1
type: internal
Port en3f0pf0sf0
Interface en3f0pf0sf0
Bridge ovsbr2
Port en3f1pf1sf0
Interface en3f1pf1sf0
Port ovsbr2
Interface ovsbr2
type: internal
Port pf1hpf
Interface pf1hpf
Port p1
Interface p1
ovs_version: “2.17.8-3feee121f”
Could you tell me how to solve it?
Many thanks
