I would like to confirm whether 10GbE operation is possible with the MCX713104AS-ADAT when using a 10GBASE-T SFP+ copper transceiver.
According to the ConnectX-7 specifications page for MCX713104AC-ADAT / MCX713104AS-ADAT, the Data Rate section shows Ethernet: 50/25GbE. However, in the same section, the “Ethernet Protocols supported by the electrical interface” list includes 10GBASE-R and SFI.
Because of this, I would like to confirm the following:
Can the MCX713104AS-ADAT establish a 10GbE link when a Methode DM7053 (10GBASE-T SFP+ RJ45 transceiver) is inserted into one of its SFP56 ports?
If yes, is this configuration officially supported or validated by NVIDIA?
Are there any known limitations, required firmware versions, auto-negotiation settings, or compatibility concerns for this use case?
At this stage, I am not asking about a specific end device yet. I first want to confirm whether the basic combination below is supported:
NIC: MCX713104AS-ADAT
Transceiver: Methode DM7053
Link type: 10GBASE-T over RJ45 copper
Target link speed: 10GbE
If possible, please also let me know whether there is any recommended NVIDIA-qualified 10GBASE-T SFP+ module for this card.
Thank you.
