Constant Array Usage Problem
I have a single .cu file. I have a array which will be used by all threads in all the blocks per grid. So i wanted to declare it as device constant.
I have done like this:-
device constant int* conarray;
global void readTexels(int n, int* oarray)
int ind=blockIdx.x + blockDim.x + threadIdx.x;
if(ind<n)
oarray[ind]=conarray[ind];
int main()
int N = 10;
cudaMalloc((void**)&conarray,sizeof(int)N);
int data = (int)malloc(N
sizeof(int));
for (int i = 0; i < N; i++)
data[i] = i;
cudaMemcpyToSymbol(“conarray”,&data,N*sizeof(int));
//Kernel Call goes here
I am just trying to copy the value of constant array ( carray) to the argument passed to the kernel call.
But i am not getting the same value as there is data.
What am i doing wrong?
Thank you
miztaken
is there any other way this can be achieved…
i want one global array ( 12288 bytes) defined…so that every thread of every block of a grid can use it.
is constant my only bait?
thanks
Instead of using cudaMemcpyToSymbol(), i tried using cudaMemcpy() method… i dont get any error and output is not correct as well… i get all the zeros…
here is my total code…
#include <stdio.h>
#include<cuda.h>
#include<stdlib.h>
void checkCUDAError(const char msg)
cudaError_t err = cudaGetLastError();
if( cudaSuccess != err)
fprintf(stderr, “Cuda error: %s: %s.\n”, msg, cudaGetErrorString( err) );
exit(EXIT_FAILURE);
constant int
conarray;
global void readTexels(int n, int* d_out)
int tid=threadIdx.x;
if(ind<n)
d_out[ind]=conarray[ind];
#define NUM_THREADS 512
int main()
int N = 10;
cudaMalloc((void**)&conarray,sizeof(int)*N);
checkCUDAError(“initilize constant array”);
int nBlocks = N/NUM_THREADS + ((N % NUM_THREADS)?1:0);
int* d_out;
cudaMalloc((void**)&d_out,sizeof(int)N);
int
h_out = (int*)malloc(sizeof(int)N);
sizeof(int));
data[i] = i;
cudaMemcpy(conarray,data,Nsizeof(int),cudaMemcpyHostToDevic
e);
checkCUDAError(“copy data to constant array”);
readTexels<<<nBlocks,NUM_THREADS>>>(N,d_out);
checkCUDAError(“Call Kernel Function”);
cudaMemcpy(h_out, d_out,N
sizeof(int), cudaMemcpyDeviceToHost);
checkCUDAError(“copy from device to host”);
printf("%d %d\n ",data[i],h_out[i]);
any clues??
thank you
miztaken
This is now solved
Instead of using this
I used this
constant int conarray[10000];
and it worked
i still dont know what it didnt work? due to dynamic allocation, but it must be possible??
take care
miztaken :thumbup:
