Consuming a populated JIT cache with read-only permissions
I have a JIT cache that’s already been populated. And I’m seeing the expected speed-up when I load my CUDA application using this cache.
But I have restrictions that require me to make the JIT cache directory read-only. Once it’s read-only, JIT compilation and loading becomes slow again… suggesting that the cache is not being used.
Is it required to have the JIT cache directory as read+write-enabled, even though we just want to only read from it?
Does setting the Cuda environment variable “CUDA_DISABLE_PTX_JIT” help?
No, it doesn’t seem like it.
Setting CUDA_DISABLE_PTX_JIT=1 makes the load to fail.
It looks like the GPU binary code is expected to be embedded in the CUDA application if CUDA_DISABLE_PTX_JIT is set…
In my case, I want to read from the JIT cache.
You could file a bug if you wish.
