Control GPIO pin on JP6
I want to control the GPIO.09 on my Orin nano dev-kit.
I use SDK-Manager to flash to LT4 “R36 (release), REVISION: 3.0”.
01.When I use gpioinfo command to query GPIO9, it shows
1_default
, and the measured voltage is 0.
02.Then I use gpioset to pull high,
2_setvalue1
it shows
3_setvalue1_query
But the measured voltage is still 0.
How can I control the GPIO.09 or other GPIO pins when L4T version is 36.3.0 ?
You should run these commands with sudo permission.
I have run the sudo su before using the gpio commands.
The prompt is “#” (root mode), not $(user mode)
Oh sure, sorry I missed it.
Did you update the pinmux correctly so the pin is really an output pin?
Does the same pin work with JetPack 5 where you can directly control it with sysfs?
When I use L4T 35.4.1, I don’t need to do any modification.
Gpio command and sysfs are fine to control the GPIO pins(1,7,9,11) of 40 header pin.
Then please check this.
After seting the pinmux to output, it works by gpio command and sysfs,thanks.
