Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I have a doubt regarding the replay frame rate. I took the example rig files. I have managed to make a h264 video which when I play using vlc player plays at the right frame rate i set it to when making. say 1fps . But when I use camera_extra application in driverworks and try to play this back, it plays around 7`-9 fps.
This is the parameter line of rig file.
“parameter”: “video=myvideo.h264,timestamp=video_time_0.txt”,
This video_time_0.txt, I tried to use the default available in docker, I also tried making one with 1 second gap between every frame time. I still see its playing at 7-9 fps.
Hence my question;
How do i control the frame rate in replay?
Is this replay somehow related to the value i have configured in the fsync generator?
Is it possible to keep replaying in loop without rerunning the application again and again?
@VickNV while using the camera extra app I tried to use offscreen parameter of the app. The display window pops up and I see the frame rate embedded there in the GL window down left. Is that not the right value?
Could you please share a screenshot of the display window where the frame rate is shown? Additionally, could you provide the exact command or parameters you used to run the camera_extra application with the offscreen option?
This is the run with offscreen=0. (I don’t see the replay video visual may be some codec thing not sure, but I have dumped the frames to confirm I see the frames as these are 8mp camera images stitched together)
Command used is : ./sample_camera_extra --offscreen=0 --profiling=1 --rig=rig.json
Any leads on these questions?
1. How do i control the frame rate in replay?
2. Is this replay somehow related to the value i have configured in the fsync generator?
3. Is it possible to keep replaying in loop without rerunning the application again and again?
Here’s the relevant section from DriveWorksSample.hpp that sets the rendering rate:
* @brief setRenderRate This controls how fast the render callback is called.
* @param loopsPerSecond The max number of times render should be called per
* second. Default is 60fps.
* @note If loopsPerSecond is 0 then no limitation happens.
void setRenderRate(int loopsPerSecond);
You can use this as a reference to adjust the rendering rate in your application. If you have hands-on access to the code, consider exploring these files to understand how you might alter or work with the rendering rate.
