Hi Forum,
I used the following command to convert the .dtsi files generated from the modification of the default pinmux spreadsheet :
$ cd <path-to/Linux_for_Tegra/kernel/pinmux/t19x
$ python3 pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt --mandatory_pinmux_file mandatory_pinmux.txt ~/Workspace/tegra19x_custom_board_pinmux_v2/tegra19x-custom_board-pinmux.dtsi ~/Workspace/tegra19x_custom_board_pinmux_v2/tegra19x-custom_board-gpio-default.dtsi 1.0 > my_custom_board.cfg
However, I got following error :
ERROR: pin dap3_sclk_pt1(0x00000440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dap3_fs_pt4(0x00000440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin eqos_rd3_pf1(0x00022470) field nvidia,lpbk(0x00000020) is not matching, val = 0x01 expected = 0x00
ERROR: pin eqos_sma_mdio_pf4(0x00022440) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin sdmmc4_cmd(0x00002440) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin soc_gpio10_pg6(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin gp_pwm2_px2(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin uart2_tx_px4(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart2_rx_px5(0x00000450) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin can0_dout_paa2(0x0000c400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin can0_din_paa3(0x0000c450) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart3_tx_pcc5(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart3_rx_pcc6(0x00000450) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin soc_gpio22_pq2(0x00000459) field nvidia,pull(0x0000000c) is not matching, val = 0x02 expected = 0x00
ERROR: pin uart1_tx_pr2(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart1_rx_pr3(0x00000454) field nvidia,pull(0x0000000c) is not matching, val = 0x01 expected = 0x02
But the output file (my_custom_board.cfg) was still generated.
I then removed the –mandatory_pinmux_file option and it went well.
My question is that what is the purpose of the mandatory_pinmux.txt file input to the pinmux-dts2cfg.py script and can I omit it, please ?
Best Regards,
Khang
