Software Version
[+] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[+] Linux
QNX
other
Hardware Platform
[+] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
[+] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
I am trying to convert an onnx model using tesnorrt but I get the following error. Do you have any feedback on that
/usr/src/tensorrt/bin/trtexec_debug --onnx=objectDetector_ALPS.onnx
&&&& RUNNING TensorRT.trtexec [TensorRT v8205] # /usr/src/tensorrt/bin/trtexec_debug --onnx=objectDetector_ALPS.onnx
[07/23/2024-10:29:12] [I] === Model Options ===
[07/23/2024-10:29:12] [I] Format: ONNX
[07/23/2024-10:29:12] [I] Model: objectDetector_ALPS.onnx
[07/23/2024-10:29:12] [I] Output:
[07/23/2024-10:29:12] [I] === Build Options ===
[07/23/2024-10:29:12] [I] Max batch: explicit batch
[07/23/2024-10:29:12] [I] Workspace: 16 MiB
[07/23/2024-10:29:12] [I] minTiming: 1
[07/23/2024-10:29:12] [I] avgTiming: 8
[07/23/2024-10:29:12] [I] Precision: FP32
[07/23/2024-10:29:12] [I] Calibration:
[07/23/2024-10:29:12] [I] Refit: Disabled
[07/23/2024-10:29:12] [I] Sparsity: Disabled
[07/23/2024-10:29:12] [I] Safe mode: Disabled
[07/23/2024-10:29:12] [I] DirectIO mode: Disabled
[07/23/2024-10:29:12] [I] Restricted mode: Disabled
[07/23/2024-10:29:12] [I] Save engine:
[07/23/2024-10:29:12] [I] Load engine:
[07/23/2024-10:29:12] [I] Profiling verbosity: 0
[07/23/2024-10:29:12] [I] Tactic sources: Using default tactic sources
[07/23/2024-10:29:12] [I] timingCacheMode: local
[07/23/2024-10:29:12] [I] timingCacheFile:
[07/23/2024-10:29:12] [I] Input(s)s format: fp32:CHW
[07/23/2024-10:29:12] [I] Output(s)s format: fp32:CHW
[07/23/2024-10:29:12] [I] Input build shapes: model
[07/23/2024-10:29:12] [I] Input calibration shapes: model
[07/23/2024-10:29:12] [I] === System Options ===
[07/23/2024-10:29:12] [I] Device: 0
[07/23/2024-10:29:12] [I] DLACore:
[07/23/2024-10:29:12] [I] Plugins:
[07/23/2024-10:29:12] [I] === Inference Options ===
[07/23/2024-10:29:12] [I] Batch: Explicit
[07/23/2024-10:29:12] [I] Input inference shapes: model
[07/23/2024-10:29:12] [I] Iterations: 10
[07/23/2024-10:29:12] [I] Duration: 3s (+ 200ms warm up)
[07/23/2024-10:29:12] [I] Sleep time: 0ms
[07/23/2024-10:29:12] [I] Idle time: 0ms
[07/23/2024-10:29:12] [I] Streams: 1
[07/23/2024-10:29:12] [I] ExposeDMA: Disabled
[07/23/2024-10:29:12] [I] Data transfers: Enabled
[07/23/2024-10:29:12] [I] Spin-wait: Disabled
[07/23/2024-10:29:12] [I] Multithreading: Disabled
[07/23/2024-10:29:12] [I] CUDA Graph: Disabled
[07/23/2024-10:29:12] [I] Separate profiling: Disabled
[07/23/2024-10:29:12] [I] Time Deserialize: Disabled
[07/23/2024-10:29:12] [I] Time Refit: Disabled
[07/23/2024-10:29:12] [I] Skip inference: Disabled
[07/23/2024-10:29:12] [I] Inputs:
[07/23/2024-10:29:12] [I] === Reporting Options ===
[07/23/2024-10:29:12] [I] Verbose: Disabled
[07/23/2024-10:29:12] [I] Averages: 10 inferences
[07/23/2024-10:29:12] [I] Percentile: 99
[07/23/2024-10:29:12] [I] Dump refittable layers:Disabled
[07/23/2024-10:29:12] [I] Dump output: Disabled
[07/23/2024-10:29:12] [I] Profile: Disabled
[07/23/2024-10:29:12] [I] Export timing to JSON file:
[07/23/2024-10:29:12] [I] Export output to JSON file:
[07/23/2024-10:29:12] [I] Export profile to JSON file:
[07/23/2024-10:29:12] [I] === Device Information ===
[07/23/2024-10:29:12] [I] Selected Device: Orin
[07/23/2024-10:29:12] [I] Compute Capability: 8.7
[07/23/2024-10:29:12] [I] SMs: 16
[07/23/2024-10:29:12] [I] Compute Clock Rate: 1.275 GHz
[07/23/2024-10:29:12] [I] Device Global Memory: 28902 MiB
[07/23/2024-10:29:12] [I] Shared Memory per SM: 164 KiB
[07/23/2024-10:29:12] [I] Memory Bus Width: 128 bits (ECC disabled)
[07/23/2024-10:29:12] [I] Memory Clock Rate: 1.275 GHz
[07/23/2024-10:29:12] [I] TensorRT version: 8.2.5
[07/23/2024-10:35:58] [I] [TRT] [MemUsageChange] Init CUDA: CPU +366, GPU +0, now: CPU 377, GPU 4944 (MiB)
[07/23/2024-10:35:59] [I] [TRT] [MemUsageSnapshot] Begin constructing builder kernel library: CPU 377 MiB, GPU 4944 MiB
[07/23/2024-10:35:59] [I] [TRT] [MemUsageSnapshot] End constructing builder kernel library: CPU 448 MiB, GPU 4945 MiB
[07/23/2024-10:35:59] [I] Start parsing network model
[07/23/2024-10:35:59] [I] [TRT] ----------------------------------------------------------------
[07/23/2024-10:35:59] [I] [TRT] Input filename: objectDetector_ALPS.onnx
[07/23/2024-10:35:59] [I] [TRT] ONNX IR version: 0.0.6
[07/23/2024-10:35:59] [I] [TRT] Opset version: 11
[07/23/2024-10:35:59] [I] [TRT] Producer name: pytorch
[07/23/2024-10:35:59] [I] [TRT] Producer version: 1.13.1
[07/23/2024-10:35:59] [I] [TRT] Domain:
[07/23/2024-10:35:59] [I] [TRT] Model version: 0
[07/23/2024-10:35:59] [I] [TRT] Doc string:
[07/23/2024-10:35:59] [W] [TRT] onnx2trt_utils.cpp:366: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[07/23/2024-10:35:59] [W] [TRT] onnx2trt_utils.cpp:392: One or more weights outside the range of INT32 was clamped
[07/23/2024-10:35:59] [W] [TRT] Tensor DataType is determined at build time for tensors not marked as input or output.
[07/23/2024-10:35:59] [I] Finish parsing network model
[07/23/2024-10:36:00] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +964, GPU +435, now: CPU 1571, GPU 5380 (MiB)
[07/23/2024-10:41:24] [I] [TRT] [MemUsageChange] Init cuDNN: CPU +408, GPU +1154, now: CPU 1979, GPU 6534 (MiB)
[07/23/2024-10:41:24] [I] [TRT] Local timing cache in use. Profiling results in this builder pass will not be stored.
[07/23/2024-10:41:24] [E] Error[2]: [utils.cpp::checkMemLimit::380] Error Code 2: Internal Error (Assertion upperBound != 0 failed. Unknown embedded device detected. Please update the table with the entry: {{2055, 16, 32}, 23121},)
[07/23/2024-10:41:24] [E] Error[2]: [builder.cpp::buildSerializedNetwork::609] Error Code 2: Internal Error (Assertion enginePtr != nullptr failed. )
[07/23/2024-10:41:24] [E] Engine could not be created from network
[07/23/2024-10:41:24] [E] Building engine failed
[07/23/2024-10:41:24] [E] Failed to create engine from model.
[07/23/2024-10:41:24] [E] Engine set up failed
