• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• TensorRT Version 8.6.1.6-1+cuda12.0
• NVIDIA GPU Driver Version (valid for GPU only) 535.216.01
Trying to build a model (.onnx to .engine) the following error occurs:
AttributeError: module ‘tensorrt’ has no attribute ‘Logger’
Follow the code to build the model:
import os
import argparse
from loguru import logger
import tensorrt as trt
import math
TRT_LOGGER = trt.Logger()
def build_engine(onnx_file_path, inputname, engine_file_path=“”, set_input_shape=None):
“”“Takes an ONNX file and creates a TensorRT engine to run inference with”“”
network_creation_flag = 0
network_creation_flag = 1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
with trt.Builder(TRT_LOGGER) as builder, builder.create_network(
) as network, builder.create_builder_config() as config, trt.OnnxParser(
network, TRT_LOGGER
) as parser, trt.Runtime(
TRT_LOGGER
) as runtime:
config.set_memory_pool_limit(
trt.MemoryPoolType.WORKSPACE, 1 << 28
) # 256MiB
# Parse model file
if not os.path.exists(onnx_file_path):
print(
"ONNX file {} not found, please run yolov3_to_onnx.py first to generate it.".format(
onnx_file_path
exit(0)
print("Loading ONNX file from path {}...".format(onnx_file_path))
with open(onnx_file_path, "rb") as model:
print("Beginning ONNX file parsing")
if not parser.parse(model.read()):
print("ERROR: Failed to parse the ONNX file.")
for error in range(parser.num_errors):
print(parser.get_error(error))
return None
# set input shape
profile = builder.create_optimization_profile()
logger.debug("total input layer: {}".format(network.num_inputs))
logger.debug(network.num_outputs)
output = network.get_output(0)
logger.debug(output.shape)
for i in range(network.num_inputs):
input = network.get_input(i)
# assert input.shape[0] == -1
logger.debug("input layer-{}: {}".format(i, input.name))
profile.set_shape(inputname, set_input_shape[0], set_input_shape[1], set_input_shape[2])
config.add_optimization_profile(profile)
logger.debug("build, may take a while...")
plan = builder.build_serialized_network(network, config)
engine = runtime.deserialize_cuda_engine(plan)
print("Completed creating Engine")
with open(engine_file_path, "wb") as f:
f.write(plan)
return engine
def main(args):
trt_file_name = args.onnx.replace(‘.onnx’, ‘_bs{}.trt’.format(args.batch))
input_shape = [(1, 3, args.size, args.size), (math.ceil(args.batch/2), 3, args.size, args.size), (args.batch, 3, args.size, args.size)]
logger.debug(“set input shape: {}”.format(input_shape))
build_engine(args.onnx, args.name, trt_file_name, input_shape)
if name == “main”:
parser = argparse.ArgumentParser()
parser.add_argument(‘–onnx’, type=str, default=‘/home/eduardo/Devel/Models/Arcface_DS_7.0/w600k_r50.onnx’, help=‘onnx path’)
parser.add_argument(‘-s’, ‘–size’, type=int, default=112, help=‘input shape’)
parser.add_argument(‘-b’, ‘–batch’, type=int, default=1, help=‘max batch size’)
parser.add_argument(‘-n’, ‘–name’, type=str, default=‘input.1’, help=‘input name’)
args = parser.parse_args()
main(args=args)
Notes:
The Deepstream python apps are running well.
Tesorrt was intallled according to the deepstream 7.0 installation guide:
sudo apt-get install --no-install-recommends libnvinfer-lean8=8.6.1.6-1+cuda12.0 libnvinfer-vc-plugin8=8.6.1.6-1+cuda12.0
libnvinfer-headers-dev=8.6.1.6-1+cuda12.0 libnvinfer-dev=8.6.1.6-1+cuda12.0 libnvinfer-headers-plugin-dev=8.6.1.6-1+cuda12.0
libnvinfer-plugin-dev=8.6.1.6-1+cuda12.0 libnvonnxparsers-dev=8.6.1.6-1+cuda12.0 libnvinfer-lean-dev=8.6.1.6-1+cuda12.0
libnvparsers-dev=8.6.1.6-1+cuda12.0 python3-libnvinfer-lean=8.6.1.6-1+cuda12.0 python3-libnvinfer-dispatch=8.6.1.6-1+cuda12.0
uff-converter-tf=8.6.1.6-1+cuda12.0 onnx-graphsurgeon=8.6.1.6-1+cuda12.0 libnvinfer-bin=8.6.1.6-1+cuda12.0
libnvinfer-dispatch-dev=8.6.1.6-1+cuda12.0 libnvinfer-dispatch8=8.6.1.6-1+cuda12.0 libnvonnxparsers-dev=8.6.1.6-1+cuda12.0
libnvonnxparsers8=8.6.1.6-1+cuda12.0 libnvinfer-vc-plugin-dev=8.6.1.6-1+cuda12.0 libnvinfer-samples=8.6.1.6-1+cuda12.0 -
Checking the Tensorrt installation:
dpkg -l | grep nvinfer
ii libnvinfer-bin 8.6.1.6-1+cuda12.0 amd64 TensorRT binaries
ii libnvinfer-dev 8.6.1.6-1+cuda12.0 amd64 TensorRT development libraries
ii libnvinfer-dispatch-dev 8.6.1.6-1+cuda12.0 amd64 TensorRT development dispatch runtime libraries
ii libnvinfer-dispatch8 8.6.1.6-1+cuda12.0 amd64 TensorRT dispatch runtime library
ii libnvinfer-headers-dev 8.6.1.6-1+cuda12.0 amd64 TensorRT development headers
ii libnvinfer-headers-plugin-dev 8.6.1.6-1+cuda12.0 amd64 TensorRT plugin headers
ii libnvinfer-lean-dev 8.6.1.6-1+cuda12.0 amd64 TensorRT lean runtime libraries
ii libnvinfer-lean8 8.6.1.6-1+cuda12.0 amd64 TensorRT lean runtime library
ii libnvinfer-plugin-dev 8.6.1.6-1+cuda12.0 amd64 TensorRT plugin libraries
ii libnvinfer-plugin8 8.6.1.6-1+cuda12.0 amd64 TensorRT plugin libraries
ii libnvinfer-samples 8.6.1.6-1+cuda12.0 all TensorRT samples
ii libnvinfer-vc-plugin-dev 8.6.1.6-1+cuda12.0 amd64 TensorRT vc-plugin library
ii libnvinfer-vc-plugin8 8.6.1.6-1+cuda12.0 amd64 TensorRT vc-plugin library
ii libnvinfer8 8.6.1.6-1+cuda12.0 amd64 TensorRT runtime libraries
ii python3-libnvinfer-dispatch 8.6.1.6-1+cuda12.0 amd64 Python 3 bindings for TensorRT dispatch runtime
ii python3-libnvinfer-lean 8.6.1.6-1+cuda12.0 amd64 Python 3 bindings for TensorRT lean runtime
