I am trying to convert a TF 2.0 saved_model to tensorRT on the Jetson Nano.
The model was saved in TF 2.0.0. The nano has Jetpack 4.2.2 w/ TensorRT __ and Tensorflow 1.14 (that is the latest Tensorflow release for Jetson).
I have been following the instructions from here which describe how to convert a TF 2.0.0 saved_model into TensorRT.
Below is my code:
import tensorflow as tf
from tensorflow.python.compiler.tensorrt import trt_convert as trt
tf.enable_eager_execution()
converter = trt.TrtGraphConverterV2(input_saved_model_dir=input_saved_model_dir)
converter.convert()
converter.save(output_saved_model_dir)
saved_model_loaded = tf.saved_model.load(
output_saved_model_dir, tags=[tag_constants.SERVING])
graph_func = saved_model_loaded.signatures[
signature_constants.DEFAULT_SERVING_SIGNATURE_DEF_KEY]
frozen_func = convert_to_constants.convert_variables_to_constants_v2(
graph_func)
def wrap_func(*args, **kwargs):
# Assumes frozen_func has one output tensor
return frozen_func(*args, **kwargs)[0]
output = wrap_func(input_data).numpy()
It seems to start converting successfully. However I get an KeyError: 'serving_default' error when it reaches the convert_to_tensor line. My complete printout is below found here, but the python traceback appears below. How can I fix this?
File "tst.py", line 38, in <module>
convert_savedmodel()
File "tst.py", line 24, in convert_savedmodel
converter.convert()
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/compiler/tensorrt/trt_convert.py", line 956, in convert
func = self._saved_model.signatures[self._input_saved_model_signature_key]
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/saved_model/signature_serialization.py", line 196, in __getitem__
return self._signatures[key]
Also, for anyone trying this (especially for those working in NVIDIA), the example provided in the tf.tensorrt <a target='_blank' rel='noopener noreferrer' href='https://docs.nvidia.com/deeplearning/frameworks/tf-trt-user-guide/index.html#worflow-with-savedmodel'>documentation</a> is incorrect and missing important scoping statements (e.g. tag_constants should be tf.saved_model.tag_constants). It should be:
converter.convert()
output_saved_model_dir, tags=[tf.saved_model.tag_constants.SERVING])
tf.saved_model.signature_constants.DEFAULT_SERVING_SIGNATURE_DEF_KEY]
frozen_func = trt.convert_to_constants.convert_variables_to_constants_v2(
graph_func)
Thanks for posting the corrected scoping requirements rsandler00. Note that for me (in Tensorflow 2.0) I needed to use tf.saved_model.SERVING (not tf.saved_model.tag_constants.SERVING) and (tf.saved_model.DEFAULT_SERVING_SIGNATURE_DEF_KEY).
I now get the following error in my call output = wrap_func(input_data).numpy()
ValueError: All inputs to ConcreteFunctions must be Tensors; on invocation of pruned, the 0-th input ([[ 6.0191255e+00 … 2.6921434e-02 2.6448354e-02]]) was not a Tensor.
My input_data is a 26 column numpy array. How can I successfully load this in for inference? (and get a numpy array as output).
