Hi all,
I would like to compile a CUDA source code containing the routine cusparseCreateMatDescr, but I am getting a compilation error as follows:
mkdir -p obj/
nvcc -O3 -arch=sm_86 -c cusparse.cu -o obj/cusparse.o
cusparse.cu(156): error: identifier “cusparseSdense2csr” is undefined
CHECK_CUSPARSE(cusparseSdense2csr(handle, M, N, descr, dA, M, dNnzPerRow,
cusparse.cu(160): error: identifier “cusparseScsrmv” is undefined
CHECK_CUSPARSE(cusparseScsrmv(handle, CUSPARSE_OPERATION_NON_TRANSPOSE,
2 errors detected in the compilation of “cusparse.cu”.
make: *** [Makefile:22: obj/cusparse.o] Error 2
I am using Ubuntu 20.04.1 OS; Checking the include directory
pwd
/usr/local/cuda-12.4/targets/x86_64-linux/include
grep “cusparseSdense2csr” cusparse.h
:/usr/local/cuda-12.4/targets/x86_64-linux/include$ grep -r “cusparseSdense2csr”
The cusparseSdense2csr is not in the *.h files. The version of nvcc and driver is as follows:
nvcc --version
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Thu_Mar_28_02:18:24_PDT_2024
Cuda compilation tools, release 12.4, V12.4.131
Build cuda_12.4.r12.4/compiler.34097967_0
nvidia-smi
Wed Apr 10 20:23:19 2024
| NVIDIA-SMI 550.54.15 Driver Version: 550.54.15 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3050 … Off | 00000000:01:00.0 Off | N/A |
| N/A 43C P3 N/A / 35W | 12MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1621 G /usr/lib/xorg/Xorg 4MiB |
| 0 N/A N/A 2596 G /usr/lib/xorg/Xorg 4MiB |
The compiler is failing to find the cusparseSdense2csr in the header file. Is this routine deprecated?
I saw some sample codes in the cuSPARSE 12.4 documentation using this routine. I would appreciate any guidance and help in this regard.
