Hi:
I’m facing trouble to copying an array of a struct (that contains a set of structs), and I’m a bit lost on how to solve it.
So, I had following code that is working for copying a single struct item
static void _cinit(memory** n) {
memory t;
BigInteger w;
cudaMalloc(n, sizeof(memory));
BImemcpy(&w, 2);
//device memory
cudaMalloc(&t.vt, sizeof(BigInteger));
//some more cudaMalloc
cudaMemcpy(((BigInteger*)t.vt), &w, sizeof(BigInteger), cudaMemcpyHostToDevice);
cudaMemcpy(*n, &t, sizeof(memory), cudaMemcpyHostToDevice);
int main(){
memory* m = NULL;
_cinit(&m);
so, I modified the code to make it work as an array
static void _cinit(memory** n, int cnt) {
memory t;
BigInteger w;
int i;
//cudaMalloc(n, sizeof(memory)); --> commented this line
BImemcpy(&w, 2);
//device memory
//cudaMemcpy(*n, &t, sizeof(memory), cudaMemcpyHostToDevice); --> commented this line
for (i = 0; i < cnt; i++) {
cudaMalloc(&n[i], sizeof(memory));
cudaMemcpy(n[i], &t, sizeof(memory), cudaMemcpyHostToDevice);
printf("memory %p set result: %s\n", n[i], cudaGetErrorString(cudaGetLastError()));
int main(){
int i;
memory* m = NULL;
_cinit(&m, 4);
for(i = 0;i < 4;i++){
printf("received memory: %p\n", &m[i]);
after an execution, I found that after first position of the array, pointers are not matching, making impossible to use any array position after 0.
memory 0000000701440A00 set result: no error
memory 0000000701440C00 set result: no error
memory 0000000701440E00 set result: no error
memory 0000000701441000 set result: no error
received memory: 0000000701440A00 --> same memory pointer
received memory: 0000000701440AA0 --> different memory pointer
received memory: 0000000701440B40
received memory: 0000000701440BE0
Obviously I’m doing something wrong, but I’m not able to find it… can anyone provide some hints of what’s happening here?
