Hi all,
I have a pointer to an array that is a member of a struct on the device.
struct __align__(16) Example{
float *something;
size_t something_size;
I am passing in another global memory pointer in to a kernel, and wish to copy everything in the struct array to this incoming array. Right now I am using a for loop, but there must be a better way to do this. Can anyone help with ideas?
I can not use cudaMemcpyDeviceToDevice on the host, because somehow it doesn’t work when one array is a struct member.
Current Code:
__global__ void copy (Example *myexample, float *copytoThis){
if (some condition) {
for (int i=0; i< (myexample->something_size); i++)
copytoThis[i] = myexample->something[i];
Thanks in advance!
ajk3e
March 17, 2010, 8:39pm
#2
I have the exact same issue. Were you able to find a better way to do this than a loop? Thanks!
May I ask a question? Does compiler optimize your loop to get better performance? Does such loop lower the performance?
Hi all,
float *something;
Current Code:
Thanks in advance!
