Using PGI Visual Fortran 2008 v10.9 on Win7
I made a mistake by forgetting to declare an input variable in global device subroutine. The compiler would successfully compile if that input variable is of REAL type (by default). After calling the subroutine with a device array as input, copying out would result in error and program exit. This wouldn’t happen if I had put “IMPLICIT NONE” in the device subroutine.
This is the code that could produce the error. It doesn’t really do anything as I’m just trying to find out what’s wrong.
MODULE CUDADEV
USE CUDAFOR
PARAMETER (ISIZE=4,JSIZE=10)
CONTAINS
ATTRIBUTES(GLOBAL) SUBROUTINE ABCD(M,THREAL,THINT)
REAL,DEVICE :: M(ISIZE,JSIZE)
INTEGER :: I,J
! NO DECLARATION OF INPUT VARIABLES : THREAL, THINT
I = (blockidx%x-1) * 16 + threadidx%x
J = (blockidx%y-1) * 16 + threadidx%y
IF (I <= ISIZE .AND. J <= JSIZE) THEN
IF (M(I,J) > THREAL) THEN
M(I,J) = -1
END IF
IF (J == THINT) THEN
M(I,J) = 1
END IF
END IF
RETURN
END SUBROUTINE
END MODULE
PROGRAM MAIN
USE CUDAFOR
USE CUDADEV
REAL,DEVICE :: Mdev(ISIZE,JSIZE)
REAL :: M(ISIZE,JSIZE)
DO I=1,MIN(ISIZE,JSIZE)
M(I,I) = 5
END DO
Mdev = M
CALL ABCD<<<dim3(ISIZE/16+1,JSIZE/16+1,1),dim3(16,16,1)>>>(Mdev,2.0,3.0)
WRITE (*,*) cudaGetErrorString(cudaGetLastError())
M = Mdev
WRITE(*,*) M
STOP
END PROGRAM
And here’s the output
no error
0: copyout Memcpy (host=0x4aaa48, dev=0x5100000, size=160) FAILED: 30(unknown error)
In my opinion, this error message just doesn’t help much.
