Hi, I am doing multyprocesing and I need to se the usage of every GPU core like the system monitor shows the cpu core usage. Thanks
AKravets
2
Hi @cespedesk
You might want to check out the Nsight Compute tool: https://developer.nvidia.com/nsight-compute
You can also check the corresponding forum branch:
Related topics
| How to Get the Exact Amount of Resources the GPU Uses at the Moment (e.g., Used Tensor Cores) Regardless of the Running Process | 5 | 220 | January 13, 2025 | |
| How can I get the utilization of cuda core and tensor core respectively? | 5 | 3827 | January 10, 2023 | |
| Monitoring GPU core usage by CUDA on Linux | 1 | 1953 | December 18, 2012 | |
| "tools" to monitor Tensor core usage | 1 | 2345 | December 19, 2022 | |
| Is there a tool to monitor the real time usage of the SM or the cores inside SM | 1 | 673 | October 23, 2013 | |
| Visual use of CUDA cores | 1 | 1596 | November 8, 2016 | |
| How can I know the cuda cores usage by Nsight system | 0 | 474 | January 5, 2020 | |
| measure of core load | 0 | 1076 | October 26, 2011 | |
| showing gpu utlization per process | 5 | 2316 | October 12, 2018 | |
| Get tensor core usage through nvml | 4 | 2403 | December 17, 2022 |
