I want to train the STL Geometry example from modulus using a A100 or H100 GPU, but I have a limited GPU budget and I am not sure how long it will take to run 1.2M iterations on this hardware. Are there any resources that point to time/cost of training these modulus models on different geometries?
One other thing - I saw in the example it says “The case using 10 M points… implies that the network is overfitting. Increasing the points to 20 M solves that problem and the flow field is generalized to a better resolution.”.
Did you increase the points sampled on the tessellated geometry? How did you do so?
