• Hardware Platform (Jetson / GPU): NVIDIA RTX A5000
• DeepStream Version: 6.3
• TensorRT Version: 8.6.1.6
• CUDA Version: 12.2
• NVIDIA GPU Driver Version (valid for GPU only): 535.129.03
• Issue Type( questions, new requirements, bugs): bugs
I’m trying to use an onnx file in deepstream but it fails to build trt engine with batch size greater than one with the following error
cuda_codegen.hpp:604: DCHECK(it != shape_name_map_.end()) failed. Shape tensor is not found in shape_name_map: __mye85697-HOST-(i64[1][1]so[0]p[0], mem_prop=100)
cuda_codegen.hpp:604: DCHECK(it != shape_name_map_.end()) failed. Shape tensor is not found in shape_name_map: __mye85660-HOST-(i64[1][1]so[0]p[0], mem_prop=100)
ERROR: [TRT]: 10: Could not find any implementation for node {ForeignNode[onnx::MatMul_8444 + (Unnamed Layer* 1931) [Shuffle].../ScatterND_14]}.
ERROR: [TRT]: 10: [optimizer.cpp::computeCosts::3869] Error Code 10: Internal Error (Could not find any implementation for node {ForeignNode[onnx::MatMul_8444 + (Unnamed Layer* 1931) [Shuffle].../ScatterND_14]}.)
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1124 Build engine failed from config file
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:816 failed to build trt engine.
0:05:14.693655320 332 0x5624d87c0090 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2022> [UID = 1]: build engine file failed
0:05:14.856545171 332 0x5624d87c0090 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2108> [UID = 1]: build backend context failed
0:05:14.856564079 332 0x5624d87c0090 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1282> [UID = 1]: generate backend failed, check config file settings
0:05:14.856579200 332 0x5624d87c0090 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<nvinfer0> error: Failed to create NvDsInferContext instance
0:05:14.856582381 332 0x5624d87c0090 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<nvinfer0> error: Config file path: /build/TestModels/cltr/config_infer_crowd_count_cltr.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
I increased workspace-size to 6144 but it didn’t fix the issue.
I also did two other experiments with different deepstream and TensorRT version
Experiment #1
Using nvcr.io/nvidia/deepstream:6.3-samples docker image
TensorRT Version: 8.5.3.1
The engine build failed with the same error when using the default workspace-size but worked when setting workspace-size to 6144.
Experiment #2
Using nvcr.io/nvidia/deepstream:6.4-samples-multiarch docker image
DeepStream Version: 6.4
The engine build failed with the same error when using the default workspace-size and even when setting workspace-size to 6144.
You can find the model here.
