I setup Jetson nano using SD card flash, everything works fine. But, I could not find libcudnn libraries, am I missing something or using old image to flash the nano?
Related topics
| How to manually install CUDA and all necessary packages on my Jetson Nano without SDK Manager? | 6 | 12580 | March 4, 2024 | |
| Unable to install CUDA on jetson nano help? | 11 | 14195 | October 25, 2020 | |
| Jetson nano CUDA error Could not load dynamic library 'libcudart.so.10.2' | 5 | 2359 | March 2, 2023 | |
| Cuda on jetson nano 2 GB | 1 | 483 | November 18, 2020 | |
| How to check the CUDA and cudnn setup in Jetson nano after first boot? | 3 | 1127 | July 2, 2021 | |
| Unable to install cuda support on jetson nano | 4 | 1419 | February 28, 2023 | |
| Cuda/ nvcc not found | 7 | 31929 | October 12, 2020 | |
| There is no cudnn on the Jetson Pack 32.6.1 | 2 | 1012 | August 25, 2021 | |
| How to check the CUDA and cudnn setup in Jetson nano after first boot | 1 | 2418 | June 29, 2021 | |
| Problem installing libcudnn7-dev_7 on Jetson Nano L4T R32.1 | 5 | 2804 | June 19, 2019 |
