I have flashed the .img file to micro sd card
Connected all the cables as suggested in the official website
After I placed my sd card into the slot and power on the nano, it is not reading the OS.
What wrong am i doing?
Please help out, i am stuck very badly.
Hi sameerkhansrk2012,
After copy image to SDCard, are you flash Jetson-Nano by sdkmanager or manually?
Flash by manually steps:
Put Jetson device to recovery mode.
Go to JetPack install directory: ~/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/
cd Linux_for_Tegra
Run below command to flash Jetson device:
$ sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
Thanks for your quick reply.
All i did is formatted the sd card again and did flash using sdkmanager, now it is working fine.
