Jetson nano flashing error
I am having trouble installing Jetson OS on the P3450 board.
Below is the log.
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0009 ] tegrasign --key None --getmode mode.txt
[ 0.0017 ] Assuming zero filled SBK key
[ 0.0018 ]
[ 0.0019 ] Generating RCM messages
[ 0.0028 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0037 ] RCM 0 is saved as rcm_0.rcm
[ 0.0041 ] RCM 1 is saved as rcm_1.rcm
[ 0.0042 ] List of rcm files are saved in rcm_list.xml
[ 0.0042 ]
[ 0.0042 ] Signing RCM messages
[ 0.0051 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0058 ] Assuming zero filled SBK key
[ 0.0113 ]
[ 0.0113 ] Copying signature to RCM mesages
[ 0.0122 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0323 ]
[ 0.0323 ] Parsing partition layout
[ 0.0332 ] tegraparser --pt flash.xml.tmp
[ 0.0345 ]
[ 0.0345 ] Creating list of images to be signed
[ 0.0353 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.1618 ]
[ 0.1619 ] Generating signatures
[ 0.1626 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.1632 ] Assuming zero filled SBK key
[ 0.2462 ]
[ 0.2463 ] Generating br-bct
[ 0.2472 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.2480 ] Copying Sdram info from 2 to 3 set
[ 0.2514 ]
[ 0.2514 ] Updating boot device parameters
[ 0.2521 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.2529 ] Warning: No sdram params
[ 0.2617 ]
[ 0.2617 ] Updating bl info
[ 0.2625 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.2948 ]
[ 0.2948 ] Updating secondary storage information into bct
[ 0.2955 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.3241 ]
[ 0.3241 ] Updating Odmdata
[ 0.3248 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.3255 ] Warning: No sdram params
[ 0.3610 ]
[ 0.3610 ] Get Signed section of bct
[ 0.3617 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.3624 ]
[ 0.3624 ] Signing BCT
[ 0.3636 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.3642 ] Assuming zero filled SBK key
[ 0.3647 ]
[ 0.3647 ] Updating BCT with signature
[ 0.3654 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.3950 ]
[ 0.3951 ] Copying signatures
[ 0.3957 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.5196 ]
[ 0.5196 ] Updating BFS information on BCT
[ 0.5203 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.5506 ]
[ 0.5507 ] Boot Rom communication
[ 0.5513 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.5519 ] BR_CID: 0x32101001644495832400000006fc8240
[ 0.5529 ] RCM version 0X210001
[ 0.5726 ] Boot Rom communication completed
[ 1.5795 ]
[ 1.5795 ] Sending BCTs
[ 1.5802 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 1.5809 ] Applet version 00.01.0000
[ 1.5978 ] Sending bct
[ 1.5979 ] […] 100%
[ 1.8209 ]
[ 1.8217 ] tegrahost --chip 0x21 --align cboot.bin
[ 1.8224 ]
[ 1.8230 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 1.8255 ]
[ 1.8263 ] tegrasign --key None --list cboot.bin_list.xml
[ 1.8269 ] Assuming zero filled SBK key
[ 1.8425 ]
[ 1.8431 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 1.8567 ]
[ 1.8581 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
[ 1.8588 ]
[ 1.8594 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
[ 1.8890 ]
[ 1.8899 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
[ 1.8904 ] Assuming zero filled SBK key
[ 1.8996 ]
[ 1.9005 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
[ 1.9201 ]
[ 1.9204 ] Sending bootloader and pre-requisite binaries
[ 1.9211 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
[ 1.9216 ] Applet version 00.01.0000
[ 1.9377 ] Sending ebt
[ 1.9378 ] […] 100%
[ 2.0403 ] Sending rp1
[ 2.0448 ] […] 100%
[ 2.1006 ]
[ 2.1014 ] tegrarcm --boot recovery
[ 2.1021 ] Applet version 00.01.0000
[ 2.1186 ]
[ 2.1186 ] Retrieving storage infomation
[ 2.1192 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 2.1198 ] Applet is not running on device. Continue with Bootloader
[ 2.7921 ]
[ 2.7929 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 2.7935 ] Cboot version 00.01.0000
[ 2.7953 ] Saved platform info in storage_info.bin
[ 2.7965 ]
[ 2.7965 ] Flashing the device
[ 2.7972 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 2.7979 ] Cboot version 00.01.0000
[ 2.8140 ] Partitions’ size cannot fit to storage device, total sectors 0, all partition size 3
[ 2.8140 ]
Error: Return value 4
Command tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
Failed flashing t210ref.
I tried with SDKmanager and command manually as well (sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1)
Thank you
hello craching03,
are you able bring-up the board by following Jetson Nano Developer Kit quick start guide,
please check Write Image to the microSD Card to prepare your microSD card,
you may also download Jetson Nano Developer Kit SD Card Image via Jetson download center.
thanks
