jetpack 4.5.1
32.5.1
flashing command :sudo ./flash.sh --no-systemimg JET_JN_NN mmcblk0p1
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0024 ] tegrasign --getmode mode.txt --key None
[ 0.0034 ] Assuming zero filled SBK key
[ 0.0038 ]
[ 0.0039 ] Generating RCM messages
[ 0.0061 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0070 ] RCM 0 is saved as rcm_0.rcm
[ 0.0077 ] RCM 1 is saved as rcm_1.rcm
[ 0.0077 ] List of rcm files are saved in rcm_list.xml
[ 0.0077 ]
[ 0.0077 ] Signing RCM messages
[ 0.0099 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0108 ] Assuming zero filled SBK key
[ 0.0161 ]
[ 0.0161 ] Copying signature to RCM mesages
[ 0.0186 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0211 ]
[ 0.0211 ] Parsing partition layout
[ 0.0235 ] tegraparser --pt flash.xml.tmp
[ 0.0247 ]
[ 0.0249 ] Using default ramcode: 0
[ 0.0249 ] Disable BPMP dtb trim, using default dtb
[ 0.0249 ]
[ 0.0249 ] Creating list of images to be signed
[ 0.0271 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0379 ]
[ 0.0380 ] Generating signatures
[ 0.0403 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0412 ] Assuming zero filled SBK key
[ 0.1361 ]
[ 0.1362 ] Generating br-bct
[ 0.1387 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.1436 ]
[ 0.1436 ] Updating boot device parameters
[ 0.1458 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.1468 ] Warning: No sdram params
[ 0.1471 ]
[ 0.1471 ] Updating bl info
[ 0.1489 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.1508 ]
[ 0.1509 ] Updating secondary storage information into bct
[ 0.1531 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.1552 ]
[ 0.1553 ] Updating Odmdata
[ 0.1575 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.1584 ] Warning: No sdram params
[ 0.1587 ]
[ 0.1587 ] Get Signed section of bct
[ 0.1609 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.1620 ]
[ 0.1621 ] Signing BCT
[ 0.1669 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.1681 ] Assuming zero filled SBK key
[ 0.1688 ]
[ 0.1688 ] Updating BCT with signature
[ 0.1736 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.1750 ]
[ 0.1751 ] Copying signatures
[ 0.1773 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.1871 ]
[ 0.1872 ] Updating BFS information on BCT
[ 0.1897 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.1906 ] BFS:
[ 0.1923 ] 0: [PT ] crc-flash.xml.bin (size=131072/131072)
[ 0.1929 ] 1: [TBC] nvtboot_cpu.bin.encrypt (size=65760/196608)
[ 0.1935 ] 2: [RP1] kernel_tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt (size=241264/1048576)
[ 0.1942 ] 3: [EBT] cboot.bin.encrypt (size=485392/655360)
[ 0.1947 ] 4: [WB0] warmboot.bin.encrypt (size=3952/131072)
[ 0.1951 ] 5: [BPF] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.1956 ] BFS0: 131072 @ 2560 SUM 4734d204 over 2883584 bytes
[ 0.1962 ] BFS:
[ 0.1971 ] 0: [PT-1] crc-flash.xml.bin (size=131072/131072)
[ 0.1979 ] 1: [TBC-1] nvtboot_cpu.bin.encrypt (size=65760/196608)
[ 0.1989 ] 2: [RP1-1] kernel_tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt (size=241264/1048576)
[ 0.1997 ] 3: [EBT-1] cboot.bin.encrypt (size=485392/655360)
[ 0.2002 ] 4: [WB0-1] warmboot.bin.encrypt (size=3952/131072)
[ 0.2007 ] 5: [BPF-1] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.2013 ] 8: [VER_b] emmc_bootblob_ver.txt (size=80/32768)
[ 0.2019 ] 9: [VER] emmc_bootblob_ver.txt (size=80/32768)
[ 0.2023 ] BFS1: 131072 @ 8704 SUM 4734d204 over 2981888 bytes
[ 0.2028 ] KFS:
[ 0.2379 ] 0: [DTB] kernel_tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt (size=241264/1048576)
[ 0.2387 ] 1: [TOS] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.2391 ] 2: [EKS] eks.img (size=1028/81920)
[ 0.2394 ] 3: [LNX] boot.img.encrypt (size=667648/67092480)
[ 0.2397 ] KFS0: 1048576 @ 29376546 SUM 3823fe98 over 8089600 bytes
[ 0.2461 ] KFS:
[ 0.2834 ] 0: [DTB-1] kernel_tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt (size=241264/1048576)
[ 0.2843 ] 1: [TOS-1] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.2848 ] 2: [EKS-1] eks.img (size=1028/81920)
[ 0.2852 ] 3: [LNX-1] boot.img.encrypt (size=667648/67092480)
[ 0.2857 ] KFS1: 1048576 @ 29522082 SUM 3823fe98 over 8089600 bytes
[ 0.2926 ]
[ 0.2927 ] Boot Rom communication
[ 0.2957 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.2966 ] BR_CID: 0x3210100164457783080000000a040480
[ 0.3226 ] RCM version 0X210001
[ 0.3664 ] Boot Rom communication completed
[ 1.3735 ]
[ 1.3735 ] Sending BCTs
[ 1.3760 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 1.3773 ] Applet version 00.01.0000
[ 1.4037 ] Sending bct
[ 1.4039 ] […] 100%
[ 1.6267 ]
[ 1.6291 ] tegrahost --chip 0x21 --align cboot.bin
[ 1.6300 ]
[ 1.6322 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 1.6346 ]
[ 1.6373 ] tegrasign --key None --list cboot.bin_list.xml
[ 1.6387 ] Assuming zero filled SBK key
[ 1.6517 ]
[ 1.6544 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 1.6574 ]
[ 1.6613 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-b00.dtb
[ 1.6626 ]
[ 1.6649 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-b00.dtb tegra210-p3448-0000-p3449-0000-b00.dtb_blheader
[ 1.6674 ]
[ 1.6702 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-b00.dtb_list.xml
[ 1.6716 ] Assuming zero filled SBK key
[ 1.6788 ]
[ 1.6816 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 1.6835 ]
[ 1.6840 ] Sending bootloader and pre-requisite binaries
[ 1.6866 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt 0
[ 1.6886 ] Applet version 00.01.0000
[ 1.7618 ] Sending ebt
[ 1.7626 ] […] 100%
[ 1.8711 ] Sending rp1
[ 1.8751 ] […] 100%
[ 1.9322 ]
[ 1.9375 ] tegrarcm --boot recovery
[ 1.9422 ] Applet version 00.01.0000
[ 2.0187 ]
[ 2.0188 ] Retrieving storage infomation
[ 2.0214 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 2.0226 ] Applet is not running on device. Continue with Bootloader
[ 2.5629 ]
[ 2.5653 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 2.5665 ] Cboot version 00.01.0000
[ 2.5960 ] Saved platform info in storage_info.bin
after this saved platform into in storage_info.bin it is been paused , there is no change
