Jetson Nano is not turning ON
My Jetson Nano is automatically turning off when the SD card with an Image is inserted into it. It is ON when the SD card is not Inserted or when the SD Card without an Image is inserted into it.
Having said that, I tried to Flash the Components through SDK Manager, but at the time of Flashing, it is automatically turning Off.
It is to note that the Force recovery mode is working on the Jetson Nano.
Please help to resolve this issue.
Would be a great help.
Thanks in advance.
Please share the log.
https://elinux.org/Jetson/General_debug
  • 12:45:12 DEBUG: Flash Jetson Nano (Devkit): using adapter to install NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP@JETSON_NANO_DEVKIT to /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): [ Disk Avail:127.59 GB ]
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): Using GenericInstaller to Install NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): change working directory to /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): [ Component Install Started ]
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): current working directory is /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): exec_command [host]:
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): **********************
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): #!/bin/bash
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): set -e
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): if [ -e ./bootloader/system.img ]; then
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): echo sudo ./flash.sh --no-systemimg jetson-nano-qspi-sd mmcblk0p1
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): sudo ./flash.sh --no-systemimg jetson-nano-qspi-sd mmcblk0p1
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): else
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): echo sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): fi
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): sleep 20
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): exec_command: /tmp/tmp_NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP.sh
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): ###############################################################################
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): # L4T BSP Information:
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): # R32 , REVISION: 4.3
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): # Target Board Information:
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): # Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): # OpMode: production, Boot Authentication: ,
  • 12:45:12 INFO: Flash Jetson Nano (Devkit): ./tegraflash.py --chip 0x21 --applet “/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): Welcome to Tegra Flash
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): version 1.0.0
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): Type ? or help for help and q or quit to exit
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): Use ! to execute system commands
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0073 ] Generating RCM messages
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0124 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0156 ] RCM 0 is saved as rcm_0.rcm
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0194 ] RCM 1 is saved as rcm_1.rcm
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0194 ] List of rcm files are saved in rcm_list.xml
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0195 ]
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0195 ] Signing RCM messages
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0246 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0279 ] Assuming zero filled SBK key
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0610 ]
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0611 ] Copying signature to RCM mesages
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0654 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0710 ]
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0711 ] Boot Rom communication
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0746 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
  • 12:45:13 INFO: Flash Jetson Nano (Devkit): [ 0.0781 ] RCM version 0X210001
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): [ 0.1218 ] Boot Rom communication completed
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): [ 1.1303 ]
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): [ 1.1305 ] dump EEPROM info
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): [ 1.1363 ] tegrarcm --oem platformdetails eeprom /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/cvm.bin
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): [ 1.1408 ] Applet version 00.01.0000
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): [ 1.1629 ] Saved platform info in /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/cvm.bin
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): [ 1.2385 ]
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): creating dummy /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/badpage.bin
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): 1+0 records out
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): copying bctfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): copying bootloader(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): copying initrd(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): populating kernel to rootfs… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): populating initrd to rootfs… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): populating /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): Making Boot image… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): Existing sosfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): copying tegraboot(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): copying cpu_bootloader(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): copying bpffile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): Existing badpagefile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/badpage.bin) reused.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): copying wb0boot(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): Existing tosfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): Existing eksfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/eks.img) reused.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): copying dtbfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)… done.
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): Copying nv_boot_control.conf to rootfs
  • 12:45:14 INFO: Flash Jetson Nano (Devkit): Making system.img…
  • 12:47:06 INFO: Flash Jetson Nano (Devkit): populating rootfs from /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/rootfs … done.
  • 12:47:06 INFO: Flash Jetson Nano (Devkit): populating /boot/extlinux/extlinux.conf … done.
  • 12:47:14 INFO: Flash Jetson Nano (Devkit): Sync’ing system.img … done.
  • 12:48:06 INFO: Flash Jetson Nano (Devkit): Converting RAW image to Sparse image… done.
  • 12:48:06 INFO: Flash Jetson Nano (Devkit): system.img built successfully.
  • 12:48:06 INFO: Flash Jetson Nano (Devkit): Existing tbcfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
  • 12:48:07 INFO: Flash Jetson Nano (Devkit): copying tbcdtbfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)… done.
  • 12:48:07 INFO: Flash Jetson Nano (Devkit): copying cfgfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml… done.
  • 12:48:07 INFO: Flash Jetson Nano (Devkit): copying flasher(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
  • 12:48:07 INFO: Flash Jetson Nano (Devkit): Existing flashapp(/home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/tegraflash.py) reused.
  • 12:48:07 INFO: Flash Jetson Nano (Devkit): ./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x21 --bins “EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a02.dtb”
  • 12:48:07 INFO: Flash Jetson Nano (Devkit): saving flash command in /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/flashcmd.txt
  • 12:48:08 INFO: Flash Jetson Nano (Devkit): saving Windows flash command to /home/ubuntu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/flash_win.bat
  • 12:48:08 INFO: Flash Jetson Nano (Devkit): *** Flashing target device started. ***
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): Welcome to Tegra Flash
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): version 1.0.0
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): Type ? or help for help and q or quit to exit
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): Use ! to execute system commands
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0254 ] tegrasign --key None --getmode mode.txt
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0285 ] Assuming zero filled SBK key
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0360 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0362 ] Generating RCM messages
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0408 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0481 ] RCM 0 is saved as rcm_0.rcm
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0506 ] RCM 1 is saved as rcm_1.rcm
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0506 ] List of rcm files are saved in rcm_list.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0507 ] Signing RCM messages
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0555 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0593 ] Assuming zero filled SBK key
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0882 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0883 ] Copying signature to RCM mesages
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0928 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.0999 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.1001 ] Parsing partition layout
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.1237 ] tegraparser --pt flash.xml.tmp
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.1283 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.1287 ] Creating list of images to be signed
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.1339 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.1775 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.1776 ] Generating signatures
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.1809 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.1841 ] Assuming zero filled SBK key
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2754 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2754 ] Generating br-bct
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2777 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2790 ] Copying Sdram info from 0 to 1 set
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2914 ] Copying Sdram info from 1 to 2 set
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2914 ] Copying Sdram info from 2 to 3 set
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2914 ] Updating boot device parameters
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2937 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2958 ] Warning: No sdram params
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2964 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2964 ] Updating bl info
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.2982 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3036 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3037 ] Updating secondary storage information into bct
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3048 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3067 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3067 ] Updating Odmdata
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3079 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3091 ] Warning: No sdram params
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3107 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3107 ] Get Signed section of bct
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3117 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3129 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3130 ] Signing BCT
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3148 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3159 ] Assuming zero filled SBK key
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3164 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3164 ] Updating BCT with signature
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3186 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3213 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3215 ] Copying signatures
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3246 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3461 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3463 ] Updating BFS information on BCT
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3545 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3669 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3670 ] Boot Rom communication
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3782 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.3830 ] BootRom is not running
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.4264 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.4265 ] Sending BCTs
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.4295 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.4309 ] Applet version 00.01.0000
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.4340 ] Sending bct
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.4340 ] […] 100%
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6123 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6170 ] tegrahost --chip 0x21 --align cboot.bin
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6219 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6267 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6375 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6444 ] tegrasign --key None --list cboot.bin_list.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6484 ] Assuming zero filled SBK key
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6809 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6847 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6876 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6895 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6907 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6919 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6940 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6966 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.6982 ] Assuming zero filled SBK key
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.7071 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.7086 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.7100 ]
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.7104 ] Sending bootloader and pre-requisite binaries
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.7120 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.7140 ] Applet version 00.01.0000
  • 12:48:09 INFO: Flash Jetson Nano (Devkit): [ 0.7177 ] Sending ebt
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.7192 ] […] 100%
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.8283 ] Sending rp1
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.8311 ] […] 100%
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.8897 ]
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.8990 ] tegrarcm --boot recovery
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.9031 ] Applet version 00.01.0000
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.9240 ]
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.9241 ] Retrieving storage infomation
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.9277 ] tegrarcm --oem platformdetails storage storage_info.bin
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 0.9309 ] Applet is not running on device. Continue with Bootloader
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.6773 ]
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.6805 ] tegradevflash --oem platformdetails storage storage_info.bin
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.6817 ] Cboot version 00.01.0000
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.6870 ] Saved platform info in storage_info.bin
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.6893 ]
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.6894 ] Flashing the device
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.6906 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.6919 ] Cboot version 00.01.0000
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.7069 ] Writing partition GPT with gpt.bin
  • 12:48:10 INFO: Flash Jetson Nano (Devkit): [ 1.7071 ] […] 100%
  • 12:48:11 INFO: Flash Jetson Nano (Devkit): [ 2.5621 ]
  • 12:48:11 INFO: Flash Jetson Nano (Devkit): Error: Return value 8
  • 12:48:11 INFO: Flash Jetson Nano (Devkit): Command tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
  • 12:48:11 INFO: Flash Jetson Nano (Devkit): Failed flashing t210ref.
  • 12:48:11 INFO: Flash Jetson Nano (Devkit): [ Component Install Finished with Error ]
  • 12:48:11 INFO: Flash Jetson Nano (Devkit): [ 9.41 GB used. Disk Avail: 118.18 GB ]
  • 12:48:11 INFO: Flash Jetson Nano (Devkit): [ NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP Install took 2m59s ]
    **12:48:11 SUMMARY: Flash Jetson Nano (Devkit): Failed to execute commands with GenericInstaller
We need the log from UART serial console too.
Hi @WayneWWW,
The above-sent log I am getting while I am flashing through SDK GUI.
And if I use flash Command(sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 ) via Terminal I get the Log shown below:
[ 0.0079 ] tegrasign --key None --getmode mode.txt
[ 0.0125 ] Assuming zero filled SBK key
[ 0.0151 ]
[ 0.0153 ] Generating RCM messages
[ 0.0205 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0235 ] RCM 0 is saved as rcm_0.rcm
[ 0.0274 ] RCM 1 is saved as rcm_1.rcm
[ 0.0274 ] List of rcm files are saved in rcm_list.xml
[ 0.0275 ]
[ 0.0275 ] Signing RCM messages
[ 0.0314 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0388 ] Assuming zero filled SBK key
[ 0.0621 ]
[ 0.0621 ] Copying signature to RCM mesages
[ 0.0652 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0686 ]
[ 0.0687 ] Parsing partition layout
[ 0.0774 ] tegraparser --pt flash.xml.tmp
[ 0.0859 ]
[ 0.0860 ] Creating list of images to be signed
[ 0.0894 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.1151 ]
[ 0.1152 ] Generating signatures
[ 0.1185 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.1216 ] Assuming zero filled SBK key
[ 0.2482 ]
[ 0.2482 ] Generating br-bct
[ 0.2507 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.2517 ] Copying Sdram info from 0 to 1 set
[ 0.2596 ] Copying Sdram info from 1 to 2 set
[ 0.2596 ] Copying Sdram info from 2 to 3 set
[ 0.2596 ]
[ 0.2597 ] Updating boot device parameters
[ 0.2610 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.2625 ] Warning: No sdram params
[ 0.2627 ]
[ 0.2627 ] Updating bl info
[ 0.2635 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.2719 ]
[ 0.2720 ] Updating secondary storage information into bct
[ 0.2750 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.2784 ]
[ 0.2785 ] Updating Odmdata
[ 0.2816 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 0.2872 ] Warning: No sdram params
[ 0.2897 ]
[ 0.2898 ] Get Signed section of bct
[ 0.2937 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.2972 ]
[ 0.2973 ] Signing BCT
[ 0.3030 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.3079 ] Assuming zero filled SBK key
[ 0.3119 ]
[ 0.3120 ] Updating BCT with signature
[ 0.3171 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.3216 ]
[ 0.3218 ] Copying signatures
[ 0.3251 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.3461 ]
[ 0.3462 ] Updating BFS information on BCT
[ 0.3493 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.3534 ]
[ 0.3535 ] Boot Rom communication
[ 0.3584 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.3626 ] BootRom is not running
[ 0.4089 ]
[ 0.4090 ] Sending BCTs
[ 0.4138 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.4210 ] Applet version 00.01.0000
[ 0.4242 ] Sending bct
[ 0.4250 ] […] 100%
[ 0.6034 ]
[ 0.6083 ] tegrahost --chip 0x21 --align cboot.bin
[ 0.6136 ]
[ 0.6173 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 0.6255 ]
[ 0.6297 ] tegrasign --key None --list cboot.bin_list.xml
[ 0.6359 ] Assuming zero filled SBK key
[ 0.6903 ]
[ 0.6935 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 0.6984 ]
[ 0.7031 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
[ 0.7059 ]
[ 0.7100 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
[ 0.7145 ]
[ 0.7171 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
[ 0.7185 ] Assuming zero filled SBK key
[ 0.7275 ]
[ 0.7290 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
[ 0.7304 ]
[ 0.7309 ] Sending bootloader and pre-requisite binaries
[ 0.7337 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
[ 0.7353 ] Applet version 00.01.0000
[ 0.7505 ] Sending ebt
[ 0.7512 ] […] 100%
[ 0.8623 ] Sending rp1
[ 0.8659 ] […] 100%
[ 0.9172 ]
[ 0.9217 ] tegrarcm --boot recovery
[ 0.9255 ] Applet version 00.01.0000
[ 0.9294 ]
[ 0.9296 ] Retrieving storage infomation
[ 0.9337 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 0.9393 ] Applet is not running on device. Continue with Bootloader
[ 0.9697 ]
[ 0.9871 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 0.9908 ] Cannot Open USB
[ 1.1284 ]
Command tegradevflash --oem platformdetails storage storage_info.bin
Yes, I know where this log comes from.
But this log is not what I want … please do read the website again to understand what is serial console log…
Thank you for your kind response Wayne.
One last confirmation: Jetson Nano Style - Serial Console - JetsonHacks Is this the blog to be referred? If yes, then I will continue with the steps and share the log.
Thanks in advance
Yes, that is the steps to dump serial console log.
Ok thanks a lot.
@WayneWWW, I followed the same blog(Jetson Nano Style - Serial Console - JetsonHacks) to dump the serial console, I set up the minicom and TTL serial cable connections were perfect, but after Connecting to the power cable to the nano, there is nothing on Minicom like shown in this https://youtu.be/Kwpxhw41W50?t=468 .
Would like to here from you for the further steps.
Thank you
Please check if any log is dumped from board when you start the flash process.
Wayne, this is the log I can only find under ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/rootfs/var/log dpkg.log (25.0 KB)
That log has nothing to do with your problem.
I want your log from serial console…
Please tell us the command you are using to dump serial console.
In brief, the only logs that can help your problem are:
  1. The log from your host. You already shared that.
  2. The serial log from UART you said you cannot dump.
All the other logs don’t/cannot help your problem.
Thus, I want to know how you setup (2) and what is your commands to use.
Dear @WayneWWW,
Thanks very much for this quick reply.
I have this setup for a Serial console.
May I know the next steps/commands to follow?
On your host machine, please check if there is a /dev/ttyUSB0 device.
If so, please use console tool like minicom or picocom with baud rate 115200.
For example,
sudo picocom -b 115200 /deb/ttyUSB0
Wayne, as per your guidance I had set up the Minicom with the same configuration as above and ttyUSB0 is detected.
Then please connect the power cable or run the flash command
You should see log start to show.
Wayne, Should the Empty SD card is inserted or the SD with the Image is Inserted?
And sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 is the Flash command or only flash.sh?
