my Jetson Nano doesn’t want to turn on anymore! I used it a couple of days, running the examples. Today I turned it on and the screen remained black: nothing has changed since yesterday. Power led remains green, but nothing happens. Some informations:
- using micro USB power input (5V - 2.25A power supply);
- tried to change monitor, HDMI cable, mouse, keyboard;
- reformatted micro sd and rewrote the image.
Nothing happens…
This is the serial log:
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-33e7fa82)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x123e8
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.272] Invalid GPT Partition
[0000.287] Using BFS PT to query partitions
[0000.291] failed to load NvTbootTbootCpu from (2:0)
[0000.296] re-load NvTbootTbootCpu from (4:0)
[0000.380] Csd NumOfBlocks=60579840
[0000.438] Using GPT Primary to query partitions
[0000.447] Loading Tboot-CPU binary
[0000.823] Verifying TBC in OdmNonSecureSBK mode
[0000.833] Bootloader load address is 0xa0000000, entry address is
0xa0000258
[0000.840] Bootloader downloaded successfully.
[0000.844] Downloaded Tboot-CPU binary to 0xa0000258
[0000.849] MAX77620_GPIO5 configured
[0000.853] CPU power rail is up
[0000.855] CPU clock enabled
[0000.859] Performing RAM repair
[0000.862] Updating A64 Warmreset Address to 0xa00002e9
[0000.867] Loading NvTbootBootloaderDTB
[0002.175] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0002.237] Bootloader DTB Load Address: 0x83000000
[0002.242] Loading NvTbootKernelDTB
[0003.549] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0003.610] Kernel DTB Load Address: 0x83100000
[0003.619] Loading cboot binary
[0005.298] Verifying EBT in OdmNonSecureSBK mode
[0005.341] Bootloader load address is 0x92c00000, entry address is
0x92c00258
[0005.348] Bootloader downloaded successfully.
[0005.540] Using BFS PT to query partitions
[0005.544] Next binary entry address: 0x92c00258
[0005.548] BoardId: 3448
[0005.553] Overriding pmu board id with proc board id
[0005.557] Display board id is not available
[0007.053] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0007.106] /bpmp deleted
[0007.108] SC7EntryFw header found loaded at 0xff700000
[0007.299] OVR2 PMIC
[0007.301] Bpmp FW successfully loaded
[0007.318] WB0 init successfully at 0xff780000
[0007.322] Set NvDecSticky Bits
[0007.325] GSC2 address ff53fffc value c0edbbcc
[0007.332] GSC MC Settings done
[0007.337] TOS Image length 53680
[0007.340] Monitor size 53680
[0007.343] OS size 0
[0007.504] Secure Os AES-CMAC Verification Success!
[0007.509] TOS image cipher info: plaintext
[0007.513] Loading and Validation of Secure OS Successful
[0007.529] SC7 Entry Firmware - 0xff700000, 0x4000
[0007.533] NvTbootPackSdramParams: start.
[0007.539] NvTbootPackSdramParams: done.
[0007.542] Tegraboot started after 53278 us
[0007.546] Basic modules init took 5642522 us
[0007.550] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0007.556] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0007.561] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0007.567] Storage Device Read Time = 6726 ms, Read Size = 2306 KB
[0007.572] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0007.578] Next stage binary read took 1526579 us
[0007.582] Carveout took -1538259 us
[0007.586] CPU initialization took 2039658 us
[0007.590] Total time taken by TegraBoot 7670500 us
[0007.595] Starting CPU & Halting co-processor
