The PGI fortran compiler raises an error when we use a interface inside an implementation of an abstract type. I don’t think i break the norm but i am not sure.
I made a simple example :
The abstract type :
module example_abstract
type, abstract :: foo_parent
contains
procedure(integer_interface), pass, deferred :: add_integer
procedure(real_interface), pass, deferred :: add_real
end type foo_parent
abstract interface
subroutine integer_interface(this,x)
import foo_parent
class(foo_parent) :: this
integer :: x
end subroutine
end interface
abstract interface
subroutine real_interface(this,x)
import foo_parent
real :: x
end subroutine
end interface
end module example_abstract
The implementation :
module example_module
use example_abstract
implicit none
type, extends(foo_parent) :: foo_child
integer :: int_part = 0
real :: real_part = 0.0
contains
procedure :: add_integer => add_integer_child
procedure :: add_real => add_real_child
generic :: add => add_integer, add_real
end type foo_child
interface add
module procedure add_integer_child, add_real_child
end interface add
contains
subroutine add_integer_child(this,x)
class(foo_child) :: this
integer :: x
print *,this%int_part+x
end subroutine add_integer_child
subroutine add_real_child(this,x)
real :: x
print *,this%real_part+x
end subroutine add_real_child
end module example_module
The main program:
program example_program
use example_module
implicit none
type(foo_child) :: my_foo
call my_foo%add(1)
call my_foo%add(2.)
call add(my_foo,1)
call add(my_foo,2.)
end program example_program
The result should be
$ ./a.out
1
2.000000
1
2.000000
But complier says :
$ pgfortran --version
pgfortran 14.10-0 64-bit target on x86-64 Linux -tp sandybridge
The Portland Group - PGI Compilers and Tools
Copyright (c) 2014, NVIDIA CORPORATION. All rights reserved.$ pgfortran *.F90
example_abstract.F90:
example_module.F90:
example_program.F90:
PGF90-S-0155-Could not resolve generic procedure add (example_program.F90: 9)
PGF90-S-0155-Could not resolve generic procedure add (example_program.F90: 10)
0 inform, 0 warnings, 2 severes, 0 fatal for example_program
