CPU:0, Error: cbb-fabric@0x13a00000, irq=34 in dmesg log, how to fix it?
Dear all:
1: JP5.1.2 + AGX ORIN + customed board,
2: update;
          tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
          tegra234-mb1-bct-gpio-p3701-0000-a04.dtsi
according to uphy-lane-configuration
3: update p3701.conf.common  : ODMDATA="gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-16";
4: after flash device,  lspci can see all device work normally
4: but there are so much error in dmesg log
dmesg.log (139.2 KB)
So, how to fix this error about “CPU:0, Error: cbb-fabric@0x13a00000, irq=34” ?
Hi 848145724,
Please share the full dmesg from boot up. (your current log is starting from the sec11).
Could you help to clarify what custom changes cause this issue?
and also check if the following thread helps for your case.
AGX Orin, JP5.1.2 and PCIE Endpoint Troubleshooting - #11 by waldman
以前已經說過了 要給log就給完整 要給檔案請給文字檔
I am so sorry. Due to fix some problems, the debugging serial port is disconnected from the hardware. If connected device cannot poweron. Many times it is for this same reason (debug serial port can not use in hardware), and even give up asking for help.
Of course, this is our problem. We try fix it. But it will take some time.
according to the link, I also change rootpoint pcie to x8 lane, problem solved.
Thanks all very much.
