CPU:0, Error: cbb-noc@2300000, irq=15
Jetson AGX Xavier, R3521.
When enable PCIe Controller C3, we meet some problem.Logs are as follow:
[    6.060573] tegra194-pcie 14140000.pcie: Adding to iommu group 9
[    6.150906] CPU:0, Error: cbb-noc@2300000, irq=15
[    6.151130] **************************************
[    6.151301] CPU:0, Error:cbb-noc
[    6.151389]  Error Logger            : 0
[    6.151478]  ErrLog0                 : 0x80030000
[    6.151597]    Transaction Type      : RD  - Read, Incrementing
[    6.151728]    Error Code            : SLV
[    6.151853]    Error Source          : Target
[    6.151947]    Error Description     : Target error detected by CBB slave
[    6.152103]    AXI2APB_2 bridge error: SFIFONE - Status FIFO Not Empty interrupt
[    6.152311]    AXI2APB_2 bridge error: TIM - Timer(Timeout) interrupt
[    6.152471]    Packet header Lock    : 0
[    6.152557]    Packet header Len1    : 3
[    6.152645]    NOC protocol version  : version >= 2.7
[    6.152763]  ErrLog1                 : 0x32002c
[    6.152898]  ErrLog2                 : 0x0
[    6.152971]    RouteId               : 0x32002c
[    6.153054]    InitFlow              : ccroc_p2ps/I/ccroc_p2ps
[    6.153170]    Targflow              : axis_satellite_grout/T/axis_satellite_grout
[    6.153330]    TargSubRange          : 0
[    6.153426]    SeqId                 : 0
[    6.155470]  ErrLog3                 : 0x3e20078
[    6.158962]  ErrLog4                 : 0x0
[    6.161597]    Address accessed      : 0x3e20078
[    6.166054]  ErrLog5                 : 0xb09f851
[    6.169118]    Non-Modify            : 0x1
[    6.172791]    AXI ID                : 0x16
[    6.175765]    Master ID             : CCPLEX
[    6.179174]    Security Group(GRPSEC): 0x7e
[    6.183289]    Cache                 : 0x1 -- Bufferable
[    6.187234]    Protection            : 0x2 -- Unprivileged, Non-Secure, Data Access
[    6.194317]    FALCONSEC             : 0x0
[    6.197210]    Virtual Queuing Channel(VQC): 0x0
[    6.201849]  **************************************
[    6.206942] ------------[ cut here ]------------
[    6.211385] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:2057!
[    6.218259] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[    6.223117] Modules linked in:
[    6.226538] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.104-tegra #1
[    6.233340] Hardware name: Unknown Jetson-AGX/Jetson-AGX, BIOS 2.1-32413640 01/24/2023
[    6.241070] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[    6.247206] pc : tegra194_cbb_err_isr+0x19c/0x1b0
[    6.251638] lr : tegra194_cbb_err_isr+0x11c/0x1b0
[    6.256360] sp : ffff800010003b40
[    6.260031] x29: ffff800010003b40 x28: 0000000000000001
[    6.265283] x27: 0000000000000080 x26: ffffcc0f42e4c138
[    6.270722] x25: ffffcc0f437def60 x24: 0000000000000001
[    6.276133] x23: ffffcc0f43166000 x22: ffffcc0f435ff030
[    6.281812] x21: 000000000000000f x20: 0000000000000005
[    6.287164] x19: ffffcc0f435ff020 x18: 0000000000000010
[    6.292416] x17: ffffcc0f4370b9cc x16: 000000007047e8a5
[    6.298100] x15: ffff4de00013dc70 x14: 0720072007200720
[    6.303432] x13: 0720072007200720 x12: 0720072007200720
[    6.308510] x11: 0720072007200720 x10: 0720072007200720
[    6.314294] x9 : 0720072007200720 x8 : 07200720072a072a
[    6.319534] x7 : 072a072a072a072a x6 : c0000000ffffefff
[    6.325046] x5 : 0000000000057fa8 x4 : ffffcc0f43487968
[    6.330484] x3 : 00000000ffffffff x2 : ffffcc0f4179e170
[    6.335810] x1 : ffff4de00013d700 x0 : 0000000100010100
[    6.341411] Call trace:
[    6.343884]  tegra194_cbb_err_isr+0x19c/0x1b0
[    6.348162]  __handle_irq_event_percpu+0x68/0x2a0
[    6.352630]  handle_irq_event_percpu+0x40/0xa0
[    6.356898]  handle_irq_event+0x50/0xf0
[    6.360918]  handle_fasteoi_irq+0xc0/0x170
[    6.364940]  generic_handle_irq+0x40/0x60
[    6.368977]  __handle_domain_irq+0x70/0xd0
[    6.373174]  efi_header_end+0xb0/0xf0
[    6.376411]  el1_irq+0xd0/0x180
[    6.379392]  __do_softirq+0xb4/0x3e8
[    6.383073]  irq_exit+0xc0/0xe0
[    6.386036]  __handle_domain_irq+0x74/0xd0
[    6.390061]  efi_header_end+0xb0/0xf0
[    6.393734]  el1_irq+0xd0/0x180
[    6.396983]  tegra_p2u_power_on+0x34/0x150
[    6.400993]  phy_power_on+0x98/0x110
[    6.404689]  tegra_pcie_enable_phy+0x68/0xf0
[    6.408783]  tegra_pcie_config_controller+0x138/0x450
[    6.413938]  tegra_pcie_config_rp+0x4c/0x250
[    6.418149]  tegra_pcie_dw_probe+0xae8/0x1150
[    6.422894]  platform_drv_probe+0x5c/0xb0
[    6.426979]  really_probe+0xf8/0x3d0
[    6.430312]  driver_probe_device+0x60/0xc0
[    6.434337]  device_driver_attach+0x78/0x80
[    6.438709]  __driver_attach+0x68/0xf0
[    6.442392]  bus_for_each_dev+0x84/0xe0
[    6.446576]  driver_attach+0x34/0x40
[    6.449909]  bus_add_driver+0x150/0x1f0
[    6.453848]  driver_register+0x68/0x120
[    6.457714]  __platform_driver_register+0x64/0x70
[    6.462701]  tegra_pcie_rp_init+0x24/0x2c
[    6.466794]  do_one_initcall+0x50/0x2f0
[    6.470659]  kernel_init_freeable+0x254/0x2d4
[    6.474694]  kernel_init+0x1c/0x118
[    6.478354]  ret_from_fork+0x10/0x24
[    6.481866] Code: a9446bf9 a94573fb a8c67bfd d65f03c0 (d4210000)
[    6.488014] ---[ end trace 42211aa9325362e0 ]---
[    6.492696] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[    6.500132] SMP: stopping secondary CPUs
[    6.503951] Kernel Offset: 0x4c0f315e0000 from 0xffff800010000000
[    6.510187] PHYS_OFFSET: 0xffffb22100000000
[    6.514306] CPU features: 0x8240002,03802a30
[    6.518679] Memory Limit: none
[    6.521760] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
The dts for C3:
	pcie@14140000 {
		status = "okay";
		num-lanes = <1>;
		// nvidia,max-speed = <1>;
		// max-link-speed = <1>;
		nvidia,disable-power-down;
		/delete-property/ nvidia,pex-wake;
		/delete-property/ nvidia,enable-power-down;
#if TEGRA_PCIE_VERSION >= DT_VERSION_2
		phys = <&p2u_hsio_1>;
		phy-names = "p2u-0";
#else
		phys = <&p2u_1>;
		phy-names = "pcie-p2u-0";
#endif
When we comment out the C3 node, the system can boot normally.
What might be the cause of this phenomenon?
The decompiled device tree is as follows:
adob.txt (372.1 KB)
Why are you creating a new error by yourself when default device tree already enabled C3 with correct configuration…?
We have modified the UPHY corresponding to C3. please point out where there is an error in our modification and let us know. Thank you very much.
Please tell us where the configuration is wrong?
UPHY is not able to configured on Xavier AGX. You don’t need to change anything. Restore the device tree to default setting please.
The only thing you can check is make your hardware design match the design guide document.
We have a PCIe device connected to C2 (using pin: B12, B13, K12, K13), what should we do to recognize this PCIe device?
dts are as follow:
	pcie@14120000 {
		status = "okay";
		num-lanes = <1>;
		vddio-pex-ctl-supply = <&p2888_spmic_sd3>;
That is UPHY10 of the UFS… not C2…
Read the design guide document please.
AGX Xavier能支援的 UPHY設定就只有這一組. 沒有C2. 請參考Design guide…
也就是说,AGX Xavier只支持C1(x1)、C0(x4)、C3(x1)、C4(x2)、C5(x8)这5组PCIe控制器,并且这5组PCIe的pin脚(UPHY)是固定的,无法通过Excel配置成别的pin脚(UPHY)?
是的
而且Excel本來就沒辦法配置pcie功能… Excel只是用來調整pinmux.
Pinmux只是調整功能的一部分
