I modified this file:tegra194-soc-pcie.dtsi
pcie@14160000 {
compatible = "nvidia,tegra194-pcie", "snps,dw-pcie";
power-domains = <&bpmp TEGRA194_POWER_DOMAIN_PCIEX4A>;
reg = <0x00 0x14160000 0x0 0x00020000 /* appl registers (128K) */
0x00 0x36000000 0x0 0x00040000 /* configuration space (256K) */
0x00 0x36040000 0x0 0x00040000>; /* iATU_DMA reg space (256K) */
reg-names = "appl", "config", "atu_dma";
status = "okay";
#address-cells = <3>;
#size-cells = <2>;
device_type = "pci";
num-lanes = <4>;
linux,pci-domain = <4>;
clocks = <&bpmp_clks TEGRA194_CLK_PEX0_CORE_4>,
<&bpmp_clks TEGRA194_CLK_PEX0_CORE_4M>;
clock-names = "core_clk", "core_clk_m";
resets = <&bpmp_resets TEGRA194_RESET_PEX0_CORE_4_APB>,
<&bpmp_resets TEGRA194_RESET_PEX0_CORE_4>;
reset-names = "core_apb_rst", "core_rst";
interrupts = <0 51 0x04>, /* controller interrupt */
<0 52 0x04>; /* MSI interrupt */
interrupt-names = "intr", "msi";
iommus = <&smmu TEGRA_SID_PCIE4>;
dma-coherent;
#if LINUX_VERSION >= 414
iommu-map = <0x0 &smmu TEGRA_SID_PCIE4 0x1000>;
iommu-map-mask = <0x0>;
#endif
#interrupt-cells = <1>;
interrupt-map-mask = <0 0 0 0>;
interrupt-map = <0 0 0 0 &intc 0 51 0x04>;
nvidia,dvfs-tbl = < 204000000 204000000 204000000 408000000
204000000 204000000 408000000 800000000
204000000 408000000 800000000 1600000000
0 0 0 0 >;
nvidia,max-speed = <4>;
nvidia,disable-aspm-states = <0xf>;
nvidia,controller-id = <&bpmp 0x4>;
nvidia,disable-l1-cpm;
nvidia,aux-clk-freq = <0x13>;
nvidia,preset-init = <0x5>;
nvidia,aspm-cmrt = <0x3C>;
nvidia,aspm-pwr-on-t = <0x14>;
nvidia,aspm-l0s-entrance-latency = <0x3>;
bus-range = <0x0 0xff>;
ranges = <0x81000000 0x0 0x36100000 0x0 0x36100000 0x0 0x00100000 /* downstream I/O (1MB) */
0x82000000 0x0 0x40000000 0x17 0x40000000 0x0 0xC0000000 /* non-prefetchable memory (3GB) */
0xc2000000 0x14 0x00000000 0x14 0x00000000 0x3 0x40000000>; /* prefetchable memory (13GB) */
nvidia,cfg-link-cap-l1sub = <0x1b0>;
nvidia,cap-pl16g-status = <0x174>;
nvidia,cap-pl16g-cap-off = <0x188>;
nvidia,event-cntr-ctrl = <0x1c4>;
nvidia,event-cntr-data = <0x1c8>;
nvidia,margin-port-cap = <0x190>;
nvidia,margin-lane-cntrl = <0x194>;
nvidia,dl-feature-cap = <0x2f8>;
dmesg log
nvidia@xavier:~$ dmesg | grep pcie
[ 0.926424] iommu: Adding device 14180000.pcie to group 0
[ 0.927292] iommu: Adding device 14100000.pcie to group 1
[ 0.928173] iommu: Adding device 14140000.pcie to group 2
[ 0.928952] iommu: Adding device 14160000.pcie to group 3
[ 0.929715] iommu: Adding device 141a0000.pcie to group 4
[ 0.994693] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 0.994731] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 8.123663] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 8.124555] OF: PCI: host bridge /pcie@14180000 ranges:
[ 8.638399] tegra-pcie-dw 14180000.pcie: link is down
[ 8.638522] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 8.639289] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.639296] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 8.639387] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 8.639534] pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
[ 8.639570] aer 0000:00:00.0:pcie002: unloading service driver aer
[ 8.641188] tegra-pcie-dw 14180000.pcie: PCIe link is not up…!
[ 8.642056] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 8.643109] OF: PCI: host bridge /pcie@14100000 ranges:
[ 8.750457] tegra-pcie-dw 14100000.pcie: link is up
[ 8.750741] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.764104] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.764130] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 8.764272] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 8.766482] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 8.767247] OF: PCI: host bridge /pcie@14140000 ranges:
[ 8.874483] tegra-pcie-dw 14140000.pcie: link is up
[ 8.874675] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 8.888026] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.888056] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 8.888146] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 8.920076] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 8.920087] tegra-pcie-dw 14160000.pcie: unable to find phy entries
[ 8.920253] tegra-pcie-dw 14160000.pcie: DT parsing failed: -22
[ 8.920401] tegra-pcie-dw: probe of 14160000.pcie failed with error -22
[ 8.920776] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 8.921770] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 9.435364] tegra-pcie-dw 141a0000.pcie: link is down
[ 9.435602] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.436545] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 9.436552] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 9.436671] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 9.436813] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 9.436859] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 9.438652] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
nvidia@xavier:~$
