Jason Xavier in UPHY [9: 8] C4 itself is defined as PCIe x2, although the development board is not use. But our carrier board wants to use it, how to enable it? thanks
The current settings are:
C1: PCIe x1
C0: PCIe x4
C3: PCIe x1
C4: PCIe x2
C5: PCIe x8
P0, P2, P3: USB3.1
Hi kimichang,
You could directly enable the C4 controller in DT as it is already configured as PCIe x2.
Hi WayneWWW:
I am Kimi colleague Robin, we try to do modification in DT, but It’s seem not take any effect. The SDK version is tegra-l4t-r32.4.2.
The modification in “tegra194-p2888-0000-a0.dtsi”:
pcie@141a0000 {
- status = "disabled";
+ status = "okay";
vddio-pex-ctl-supply = <&p2888_spmic_sd3>;
nvidia,disable-aspm-states = <0xf>;
nvidia,enable-power-down;
nvidia,disable-clock-request;
nvidia,plat-gpios =
<&tegra_main_gpio TEGRA194_MAIN_GPIO(Z, 2) GPIO_ACTIVE_HIGH /* 3V3 */
&tegra_main_gpio TEGRA194_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW /* 12V */
/*&tegra_main_gpio TEGRA194_MAIN_GPIO(Y, 4) GPIO_ACTIVE_HIGH */ /* I2C */
phys = <&p2u_12>,
<&p2u_13>,
<&p2u_14>,
<&p2u_15>,
<&p2u_16>,
<&p2u_17>,
<&p2u_18>,
<&p2u_19>;
phy-names = "pcie-p2u-0", "pcie-p2u-1", "pcie-p2u-2", "pcie-p2u-3",
"pcie-p2u-4", "pcie-p2u-5", "pcie-p2u-6", "pcie-p2u-7";
pcie_ep@141a0000 {
+ status = "okay";
phys = <&p2u_12>, <&p2u_13>, <&p2u_14>, <&p2u_15>,
<&p2u_16>, <&p2u_17>, <&p2u_18>, <&p2u_19>;
nvidia,pex-rst-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(GG, 1)
GPIO_ACTIVE_LOW>;
Are there any suggestions or document can provide us to enable the C4 controller, thanks.
Please use the below change to enable PCIe C4 controller
diff --git a/common/tegra194-p2888-0000-a00.dtsi b/common/tegra194-p2888-0000-a00.dtsi
index 2c5f7eb..4c01d89 100644
--- a/common/tegra194-p2888-0000-a00.dtsi
+++ b/common/tegra194-p2888-0000-a00.dtsi
@@ -133,6 +133,22 @@
phy-names = "pcie-p2u-0";
+ pcie@14160000 {
+ status = "okay";
+ vddio-pex-ctl-supply = <&p2888_spmic_sd3>;
+ nvidia,disable-aspm-states = <0xf>;
+ nvidia,enable-power-down;
+ nvidia,disable-clock-request;
+ nvidia,max-speed = <4>;
+ phys = <&p2u_8>,
+ <&p2u_9>;
+ phy-names = "pcie-p2u-0", "pcie-p2u-1";
pcie@141a0000 {
Hi Vidyas
I had another question , I use PEX_CLK2(n/p), PEX_L2_(RST/CLKREQ) to control PCIe x2. Is it must be setting for PCIe x2 and how to configured it ?
You are supposed to use PEX_CLK4(n/p), PEX_L4_(RST/CLKREQ) as the controller you are trying to use is PCIe C4 and not C2
Hi Vidyas
Thank you for your reply . I will modify hardware design on next version.
Hi, it seems the c4 can only be configured as RC, while the documents say it can be dual configured. is there any thing wrong in the document?
Which document are you referring to?
