Using nsys I would like to to profile an application executed inside a Docker container running with --privileged (following the user guide, chapter 6, User Guide — nsight-systems 2023.4.1 documentation). Even though the kernel paranoia level is set to 4, I would expect to be able to collect a profile that includes CPU sampling data by running under sudo. This, however, does not work:
$ nsys --version
NVIDIA Nsight Systems version 2022.2.1.31-5fe97ab
$ cat /proc/sys/kernel/perf_event_paranoid
4
$ sudo nsys status --environment
Timestamp counter supported: YesSampling Environment Check
Root privilege: enabled
Linux Kernel Paranoid Level = 4: Fail
Linux Distribution = Ubuntu
Linux Kernel Version = 5.8.0-44-generic: OK
Linux perf_event_open syscall available: OK
Sampling trigger event available: OK
Intel(c) Last Branch Record support: Not Available
Sampling Environment: OKNote: When Root privilege is enabled, the Linux Kernel Paranoid Level is overridden.
$ sudo nsys profile python -c 'print("foo")'
WARNING: CPU context switch tracing not supported, disabling.
Try the ‘nsys status --environment’ command to learn more.WARNING: CPU sampling not supported, disabling.
Try the ‘nsys status --environment’ command to learn more.foo
Generating ‘/tmp/nsys-report-37c1.qdstrm’
[1/1] [========================100%] report1.nsys-rep
Generated:
…/report1.nsys-rep
I can lower the paranoia level and apparently profiling works with CPU sampling, even without sudo, but I’d prefer not to as that affects processes running outside of my container, too:
$ sudo sysctl -w kernel.perf_event_paranoid=2
kernel.perf_event_paranoid = 2
2
$ nsys status --environment
Root privilege: disabled
Linux Kernel Paranoid Level = 2: OK
$ nsys profile python -c 'print("foo")'
Warning: LBR backtrace method is not supported on this platform. DWARF backtrace method will be used.
foo
Generating ‘/tmp/nsys-report-1106.qdstrm’
[1/1] [========================100%] report2.nsys-rep
Generated:
…/report2.nsys-rep
