Hi Igal,
You can check the capability of v4l2src:
nvidia@tegra-ubuntu:~$ gst-inspect-1.0 v4l2src
(ignore...)
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
image/jpeg
video/mpeg
mpegversion: 4
systemstream: false
video/mpeg
mpegversion: 2
video/mpegts
systemstream: true
video/x-bayer
format: { bggr, gbrg, grbg, rggb }
width: [ 1, 32768 ]
height: [ 1, 32768 ]
framerate: [ 0/1, 2147483647/1 ]
video/x-dv
systemstream: true
video/x-h263
variant: itu
video/x-h264
stream-format: { byte-stream, avc }
alignment: au
video/x-pwc1
width: [ 1, 32768 ]
video/x-pwc2
width: [ 1, 32768 ]
video/x-raw
format: { RGB16, BGR, RGB, GRAY8, GRAY16_LE, GRAY16_BE, YVU9, YV12, YUY2, YVYU, UYVY, Y42B, Y41B, YUV9, NV12_64Z32, NV24, NV61, NV16, NV21, NV12, I420, BGRA, BGRx, ARGB, xRGB, BGR15, RGB15 }
width: [ 1, 32768 ]
video/x-sonix
width: [ 1, 32768 ]
video/x-vp8
video/x-wmv
wmvversion: 3
format: WVC1
(ignore...)
VYUY is not supported. You can get RGB but it should be format conversion via CPU in v4l2src. No chance to reduce CPU utilization.
