I am unable to flash CPUBL-CFG partition on the Xavier NX. During the flash, I get below error:
*** Updating [CPUBL-CFG] with ***
*** Error: the file for writing CPUBL-CFG or signing is not specified. ****
My goal is to make netboot as the first preference. I am trying to follow the procedure we had followed for AGX Xavier. However, the partitions seem to be different on NX (no cpu-bootloader or CPUBL-CFG partitions).
$ sudo gdisk -l /dev/mmcblk0
GPT fdisk (gdisk) version 1.0.3
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/mmcblk0: 62521344 sectors, 29.8 GiB
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 64210415-D6C9-4F78-A55E-BAD079B8C9CE
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 62521310
Partitions will be aligned on 2048-sector boundaries
Total free space is 12441 sectors (6.1 MiB)
Number Start (sector) End (sector) Size Code Name
1 610304 62519295 29.5 GiB 8300 APP
2 2048 133119 64.0 MiB 8300 kernel
3 133120 264191 64.0 MiB 8300 kernel_b
4 264192 265087 448.0 KiB 8300 kernel-dtb
5 266240 267135 448.0 KiB 8300 kernel-dtb_b
6 268288 397311 63.0 MiB 8300 recovery
7 397312 398335 512.0 KiB 8300 recovery-dtb
8 399360 399871 256.0 KiB 8300 kernel-bootctrl
9 401408 401919 256.0 KiB 8300 kernel-bootctrl_b
10 403456 608255 100.0 MiB 8300 RECROOTFS
11 608256 608291 18.0 KiB 8300 UDA
I am trying to follow the steps mentioned at: How to boot from nfs on Xavier NX? but I think it’s only for one boot, the next time NX is booted, it falls back to booting from the SD card.
In the meantime, I am working on modifying cboot source code to make netboot as first priority with “dhcp-enabled” as default.
