Dear all,
as described in Creating a shared library that utilises OpenMP offloading there was a bug in NVHPC that did not allow the usage of offloading in libraries. The last post from @MatColgrove claimed that this should work now with NVHPC 22.5 and asked for feedback if I do see errors.
Unfortunately my simple test did not work:
$ nvc++ --version
nvc++ 22.5-0 64-bit target on x86-64 Linux -tp zen2
NVIDIA Compilers and Tools
Copyright (c) 2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
$ nvc++ -g -O3 -std=c++17 -fpic -mp=gpu -shared test_compute.cpp -o libtest_compute.so
$ nvc++ -std=c++17 test.cpp -o test -L${PWD} -ltest_compute
$ LD_LIBRARY_PATH=${PWD}:$LD_LIBRARY_PATH OMP_TARGET_OFFLOAD=MANDATORY ./test
Fatal error: Could not run target region on device 0, execution terminated.
Aborted
Moreover, if I add -mp=gpu to the compilation of test.cpp, which used to work before, I now get a wired error:
$ nvc++ -std=c++17 -mp=gpu test.cpp -o test -L${PWD} -ltest_compute
Fatal error: expression 'HX_CU_CALL_CHECK(p_cuStreamSynchronize(stream[dev]))' (value 1) is not equal to expression 'HX_SUCCESS' (value 0)
Aborted
I am unsure if this is an error on our site (we are running Driver Version: 470.57.02, CUDA Version: 11.4, A100 SMX) or if this should work. Please find my source code attached.
Best,
Andreas
test_compute.hpp (47 Bytes)
test_compute.cpp (413 Bytes)
test.cpp (686 Bytes)
Hi Andreas,
It’s an error in your code.
#pragma omp target data map(tofrom:F_x[n], X[n])
This says to copy a single element ‘n’ for the “F_x” and “X” arrays. Changing this to a range, will fix the error.
#pragma omp target data map(tofrom:F_x[:n], X[:n])
Hope this helps,
Mat
% cat test_compute.cpp
#include "test_compute.hpp"
void compute(double* X, double* F_x, int n)
#ifdef WORKS
#else
// original failing verson
#endif
#pragma omp target teams distribute parallel for
for (int k = 0; k < n; k++)
for (int l = 0; l < n; l++)
F_x[k] += (X[l] <= X[k]);
F_x[k] /= n;
} // #pragma omp target
% nvc++ -g -O3 -std=c++17 -fpic -mp=gpu -shared test_compute.cpp -o libtest_compute.so
% nvc++ -mp=gpu -std=c++17 test.cpp -o test -L./ -ltest_compute
% echo $OMP_TARGET_OFFLOAD
MANDATORY
% ./test
Abort
% nvc++ -g -O3 -std=c++17 -fpic -mp=gpu -shared test_compute.cpp -DWORKS -o libtest_compute.so
% ./test
0.4,0.1,0.3,0.8,0.9,1,0.5,0.6,0.2,0.7
Hey,
Thanks a lot. I should have seen that ^^. That actually fixed the wired CUDA error.
However, the shared library part still does not work. I.e. if you do not add -mp=gpu to the compilation of text.cpp, the execution still fails:
Aborted
As I am working on a python extension, I cannot add -mp=gpu to the primary executable (i.e. the python binary).
Best,
Andreas
Yes, that’s correct when using nvc++ to link. The problem being that without -mp=gpu, the binary initialization is set to not use the GPU, over ridding the GPU initialization in the shared object.
If using g++ to link (and presumably with python), the shard object GPU initialization will kick in when the library is loaded.
% nvc++ -V22.5 -g -O3 -fpic -mp=gpu -shared test_compute.cpp -o libtest_compute.so
% g++ test.cpp -L. -ltest_compute -o test
% ./test
0.9,0.3,0.2,0.5,0.1,1,0.4,0.7,0.8,0.6
Apologies if this was not clear.
-Mat
That makes sense, though it does not seem obvious to me.
I just double-checked and it works well. Thank you a lot 😄.
Best,
Andreas
